What header bolts are you guys running?
Kleeborp the Moderator™
I've used stock bolts, Stage 8 "locking" bolts without the locks because I was too lazy to install them, and now use ARP header studs.
I like the header studs the best...the passenger side went really nice since I was able to hang the gaskets on the studs before sliding the header in. The driver's side was still a pain in the *** since I couldn't install a single stud before sliding the header in place, but that's probably because of how I was installing them (with everything including the oil filter, steering linkage, etc still in place).
They sure look nice though, and I should never have to replace them.
Right, and when the bolt breaks off flush with the head and you have to pull the head to have the piece removed, costing you a LOT of labor and a head gasket, and possibly a set of stock head bolts, maybe even having to have your head re-milled for flatness.....all because you were too cheap to buy a $50 set of bolts.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
