FAST 102 "Truck" Intake (**NEW** Chassis dyno results added!)
#86
I just read that about the lsxr last night. Im on the fence about going with the LSXRT or the LSXR. The LSXRT has to kick the LSXR's *** for me to cut up my car. I need to see some results.
#87
That was with stock heads! At the end of the day on a good set of heads I suspect one of my ported truck intakes could be worth an additional 20 HP peak (more past peak) and in the vicinity of 15 - 20 ft/lbs of torque over and above a ported LSXR manifold.
While that isn't going to make your car feel altogether different, its not an insignificant power gain but does come at the expense of alot of work getting it to fit under the hood of an F-Body and especially a Vette.
For most of us its a big tease truthfully (and its kinda painful to know there is a manifold available that is that much better). Unfortunately it just comes with a host of fitment issues that make it an option for only a select few willing to go thru all the trouble. Now if I was reading this and modding a truck or a different hot rod that had the room I would have a pretty big grin plastered on my face right now!
-Tony
#89
dr whigham, What I,m referring to is the single motor assembly,s that you see on large aluminum step or panel vans. My former utilimaster p-30 work truck had a set that was purchased through a company called mill supply in their step van / walk in van catalog. They were a universal design, had delay.Haven,t had a chance to look at a f-body or the wiper motor to see for myself if it,s possible, but it sounds like it could be . You could call a few junkyards or truck places for something used or to at least look at.
Being an innovator takes footwork to make it happed. I just came up with the thought.
By the way, I grew up in Gueydan, think you know where that,s at & why one would leave.
#90
The Scammer Hammer
LOL! Yep.
Thanks for the clarification. I'm also wondering if I could maybe relocate the motor itself and run a few cam arms to the wiper assembly that way.
Sorry to muck the thread Tony, but thanks so much for posting the results. As soon as the property sells, I'll be calling you.
#96
You probably would need a cowl induction hood at worst. You,d jusr need to measure the listed height next to the room you have.
One would fit in my 83 el camino with my 2.5" cowl hood last I checked.
#97
