haters gonna hate
Old Dec 22, 2011 | 04:58 AM
ws6outlaw's Avatar
Default haters gonna hate
about to run my tsp dumps over the axle and out the back. gonna go non-stainless non-mandrel bends. opinions?
Old Dec 22, 2011 | 05:54 AM
djfury05's Avatar
gay.. cheap.. hate it
Old Dec 22, 2011 | 05:56 AM
Bramlok's Avatar
Sounds half *** and cheap but whatever....it's your beater.
Old Dec 22, 2011 | 05:58 AM
BOBS99SS's Avatar
Captain Double Post
lmfao
Old Dec 22, 2011 | 06:07 AM
Blk98Vert's Avatar
Why cant you go mandrel? I understand using aluminized but dont half *** it with crush bends
Old Dec 22, 2011 | 08:21 AM
Deviant LS1's Avatar
Aluminized piping is okay but with the non-mandrel bends you'll be leaving some power on the table since the crush bends will be smaller then the diameter of the pipe. Will be significant? Not at all.
Old Dec 22, 2011 | 08:42 AM
IRONFIST's Avatar
I have a similar set up on my '76, put it on in 2001 and it still has zero rust, sounds mean. The lack of mandrel bending might cost some power, but when you're running dual 2.5" pipe in the first place I don't see a little restriction being a huge deal.
Just have to take care of it.
Old Dec 22, 2011 | 10:13 AM
justin hover's Avatar
Sounds fine..Many way's to go with it, over/under axle, whatever bends you see fit, whatever pipe you see fit (keep rust in mind) ...When it's done you tell us...
Old Dec 22, 2011 | 10:47 AM
thunderstruck507's Avatar
Point of thread being? You've already made up your mind to do it so what do you want? A cookie?
Old Dec 22, 2011 | 12:19 PM
TheSilverOne's Avatar
attention ***** who is also a cheap bastard. awesome!
Old Dec 22, 2011 | 02:03 PM
ws6outlaw's Avatar
@ironfist- im running 3 in piping all the way out. And purpose of the thread is to throw an idea and see the responses. Plus its fun to see all the haters. Besides 3 in piping w/ crushed bends will out flow any ORY + catback setup. Don't care too much about the viewpoint when its under a lift anyway
Old Dec 22, 2011 | 02:06 PM
ws6outlaw's Avatar
Oh and if anyone can recommend a recently priced place with a mandrel bender in east tx id consider going mandrel bent.
Old Dec 22, 2011 | 05:08 PM
Still confused on your title..."Haters gonna hate" invites negative responses, doesn't really make sense either. Your not comparing your question to anything so why would haters hate???
Sounds like any other custom TD setup...Do it how you want it done...Than tell us if it were a good decision...Sounds fine to me....Stainless is up to you...If you go to an exhaust shop to have them fab it up you might change your mind on bends or take some of their advice..Theirs so many custom ways to go with TDs kinda hard to say one is better than the other...and yeah a td setup is better flowing and sounds better imao than any y setup...but thats personal preference..
Old Dec 22, 2011 | 05:21 PM
MikeWS6's Avatar
In for the lolz
Old Dec 22, 2011 | 05:44 PM
Guitar's Avatar
I guess if you don't care about your car go ahead.
Old Dec 22, 2011 | 07:17 PM
ws6outlaw's Avatar
How does what I said equate to I don't care about my car?
And im comparing this setup to a stainless bandrel bent setup that some others are saying is the only "right" way to run duals.
I want others to tell me exactly why this particular setup is so horrendous.
Old Dec 22, 2011 | 07:45 PM
MeentSS02's Avatar
Kleeborp the Moderator™
About the only thing I'll warn against is the potential routing issues - since you're extending TSP dumps, chances are you'll be trying to get a shop to run the pipes over both sides of the axle due to their current routing (it would make more sense than trying to pass both pipes back under the driveshaft to make it over to the passenger side). The problem you'll find is that there's an upper panhard brace that'll be in the way in addition to the brake lines, fuel lines, and various connectors related to both systems that are all on that side of the car, so you'll be exposing them to extra heat where heat isn't wanted.
People have removed that upper brace and been fine, but for a street car, I'd be more comfortable leaving that where it is since it helps brace the body side panhard rod connection, and I'd be damned if I wanted a hot exhaust pipe running next to fuel/brake lines without some sort of heat shield in place.
Just keep those things in mind, and the mandrel vs. crushed, stainless vs. aluminized will be dictated by your wallet and the quality of the shops in your area. Probably mostly by your wallet. The performance difference in crushed vs. mandrel on a typical street car will probably not be noticeable.
Old Dec 22, 2011 | 07:47 PM
It's not that bad,personal preference and budget is on you, but their are better/more expensive way's to assure great quality and durability.
Old Dec 22, 2011 | 07:58 PM
BrntWS6's Avatar
That's why people run a good merge with a cut-out. Pat G dyno tested back 2 back runs with open headers and then through the cut-out and only lost 1hp. I can't remember what he lost with the cut-out closed but it wasn't much. There are guys running 9's with y-pipes.
Old Dec 22, 2011 | 08:03 PM
Sladester2's Avatar
if its loud.. i like it
