Tsp stainless vs. Bbk on install and fit
You car has minimal mods, and like you stated you dont have too much planned for the car in the future. My car is already a h/c/i LS1 and within the next 3-5 years will be a h/c/i LS2, so buying TSP's 1 7/8" now will free some hp but in the future will shine even more. Just my .02
What's easy to some, could be tedious to others.
I'll tell you this though, I've had my TSP headers installed the better part of over a month now, with over 3 thousand miles, and haven't had a vibration or melted wire or anything yet.
1. the kooks needed the steering knuckle taken off, oil plug off and a tad bit of grinding on the k member.
2. the pacesetters needed the steering knuckle off, oil filter and plug off, the block tab cut and the k member grounded.
3.the Grots just needed the knuckle and k member ground down a bit.
4.TSP 1 7/8 I have never installed these but everyone i have seen has had to undo the motor mounts and jack the engine to one side to get them to fit.
My bbk's needed NOTHING, I left the steering knuckle in place, the oil plug in place, and never touched any part of the k member, they just slid right up and have been on the car now over 2 yrs and still dont really have any rust on them (mine are chrome finished). All the headers I have posted have good clearance once installed I would rank the bbk's and the kooks as the best but the bbks were def the easiest to instal;.
I understand your worry about the y pipe. But again think about what we are all saying if you are a stock car or lightly modded the ls1 cannot physically pump enough air to make the 3" y necessary. I mean if your catback is 3" and its only 1 pipe what good is stuffing two other 3" pipes into it going to do? The two 2.5" pipes going into the 3" catback is more than adequate. People who dyno their bbk headers get right around 25whp with a tune which is the same as other header brands.
One point I want you to keep in mind though-
I think at one point we've ALL said, "Yeah, it's just a minor bolt-on car that will never be anything else...." and before you know it you're back to scouring the classifieds for a good deal on another part. Power is addicting. Headers are a mod you WILL feel.
Final thought though. As far as saying what's the point of 2 3" pipes merging into one 3"....
You have to remember that one 3" pipe, or 2.5" is only seeing one bank of the engine. One side. Yeah, it's merging into a single 3" catback, but there's no "slamming" of anything together if your merge is worth a ****, as the TSP is, and as far as I've seen, the BBK is as well. It's all going to a 3" catback, but it isn't like you're maxing out both legs o the y pipe and tryin to cram it into a single 3" I pipe.
A 3" y will give you room to grow however.
OP, there's a lot of opinion in this thread, but the good news is there is also a lot of first hand experience. In the end, you've got to deduce what YOU want and what YOUR goals are.
I think the bbk's are what will be going in my car. I just feel that a car that is mint pristine should get the best fitting header. And the car is not going that fast anytime soon, I just want to get the best for my money and for $475 shipped with the y pipe for the coated ones, I don't see how I can go wrong.
its good to know the bbks go in easy
