Mids Vs. LT's
Old Mar 16, 2004 | 08:30 PM
ohhiitznik's Avatar
Default Mids Vs. LT's
Pros and cons. I did a search but couldnt really find what I'm looking for. I'm going with a MTI stealth cam I/II. I cant really see that big of a difference in MIDS and LT's Can someone please explain why LT's are that much better for cammed motors?
Old Mar 16, 2004 | 08:52 PM
WS6FirebirdTA00's Avatar
they let the air flow out better and cause less restriction. do it right the first time and get full lengths, u get a little more power and a nice sound too
Old Mar 16, 2004 | 09:09 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
No real difference in power in the higher rpms or at peak; a little more power in the lower rpms with LTs. You'll get more mid-range and low end TQ out of the LTs though.
Nothing wrong with going mids. No clearance issues, no banging on floor boards, and much less chance of front O2 sensor heater codes from mids (I haven't had a code in the 2 years I've had them) than LTs also. I'm VERY happy I went with mids after seeing some of the issues my friends have been through with LTs (both with install and ground clearance & floor board banging issues).
Old Mar 16, 2004 | 09:13 PM
Tally TransAm's Avatar
lt give you more low end, top end will be the same
Old Mar 16, 2004 | 09:15 PM
i have no issues with my lt's fit great and all. i was thinkin about some macs but i went with pacesetters when they were still real cheap. i do get heater codes on the driver side. gonna replace the o2s but it may be cause im taped into that wire for the a/f gauge
Old Mar 16, 2004 | 09:56 PM
ohhiitznik's Avatar
No egr/air for me and no rear O2's michigan ROX! anwyay i decided to go with pacesetters due to the fact they scavenge better, And ill be running true duals Pacesetter y pipe!
Old Mar 16, 2004 | 09:58 PM
yeah i took off all my stuff, nc sucks just rocks that i can inspect cars lol
Old Mar 16, 2004 | 10:05 PM
wfols1's Avatar
I thought the LT provide more Mid to High end power and Shortys give you more Low to Mid...This has been my experience.
With the LTs you WILL produce more TQ on the big end.
Which is what propells your car down the 1320.
I had BBK shorties on my 2001 Z06 and my buddy had the FLPs LTs on his 2002 Z06 I had 8ft Lbs TQ less and 1.5 HP more than him,I had a Borla Catback up against his Stock Catback.
This is just my opinion.
Old Mar 16, 2004 | 10:08 PM
RPM WS6's Avatar
High end power is basically the same for mids and LTs. Actually, some people have made MORE high end power with mids than LTs.
Old Mar 16, 2004 | 11:27 PM
Benjamin Russick's Avatar
Um, LTs make more power down low with the mids catching up near the top. A set of MACs with the collector mod and some clean up on the welds will flow pretty damn well. I've had both and yes, I now am running LTs, but have no complaints about MAC mids.
Old Mar 17, 2004 | 01:15 AM
16nrollininaws6's Avatar
Like they said, with LT's you will get a little more torque and a SLIGHT hp increase over the Macs. They both rock though, just stay as far away from shorties as you can for the LS1. They will gain nearly nothing on 00-02 cars, and slightly on an 98-99. Look for the best deal!
Old Mar 17, 2004 | 07:52 AM
jrp's Avatar
jrp
SN95 Director
how could you not find what your looking for theres been several huge mac vs lt threads. look in my exhaust guide and you'll see the mac vs lt dyno i pulled from one of those threads.
