Power steering thread size
Old Jan 9, 2012 | 03:26 PM
FasTimeSS's Avatar
Default Power steering thread size
I pulled off my power sterring and need to replace the open holes with some fittings anyone know the sizes? I know the two are different i believe one is 3/8"?
Thanks
Old Jan 9, 2012 | 03:34 PM
NemeSS's Avatar
The ones on the rack are m16x1.5 and m18x1.5
If ur making your own lines. Summit sells fittings for ps.
Oring fittings m16x1.5 to -6
And m18x1.5 to -6. So u can use -6 line to make hoses.
Fittings are like 16$.
If this is for a 98-02 fbody
U will need
M16x1.5 to -6 fitting for ps pump resevoir
M16x1.5 to -6
M18x1.5 to -6
For steering rack
And about 5ft of -6 ps high pressure line. The low pressure side can use a hose clamp on the ps reservoir side on the nipple on the reservoir.
Old Jan 9, 2012 | 03:38 PM
NemeSS's Avatar
Less than a 100$ if I plan on running your route for lines for turbo/headunit clearance,etc.
I make my own lines when build hotparts. But I also use a different power steering pump and remote reservoir I came up with and eliminate the stock fbody ps pump.
Looks cleaner, more clearance, remote reservoir. Steel pulley, ps pump bolt access without removing pulley
Old Jan 9, 2012 | 03:46 PM
FasTimeSS's Avatar
Perfect thanks, im just deleting power steering and i plan on running jus a hose with barb fittings on each in replace of the hard lines
Old Jan 9, 2012 | 03:58 PM
NemeSS's Avatar
Get the fittings for the rack. And get the -6 caps they sell. To cap off the fittings
Old Jan 9, 2012 | 03:59 PM
NemeSS's Avatar
Or can use hose to loop them. Whichever works
Old Jan 9, 2012 | 05:15 PM
FasTimeSS's Avatar
is it ok if i just cap it? i wasnt sure.
Old Jan 9, 2012 | 07:26 PM
NemeSS's Avatar
Loop it just in case. Use some hose.
Old Jan 9, 2012 | 10:15 PM
FasTimeSS's Avatar
Solid choice
Old Jan 9, 2012 | 11:57 PM
00pooterSS's Avatar
If I remember right, if you block off the holes you can't turn it because the pressure buildup in the rack when you turn one way to the other has no way to escape. If it were mine and I were doing away with it, I would just leave them open...
Old Jan 10, 2012 | 12:52 PM
NemeSS's Avatar
A section of hose to each other should b fine. I've never had to run w/o a ps pump in a 4th gen. But I have seen many people do so on here.
I just always run the lines different. I hate those stock metal/rubber lines.
Old Jan 12, 2012 | 12:20 PM
NemeSS's Avatar
I ordered some parts to re route the lines. Found the fittings and lines for lower price than summit. May have to fo write up on this, I get asked about often
Old Jan 12, 2012 | 04:13 PM
FasTimeSS's Avatar
please pm me and tell me what you did. thanks. im not sure if i want to loop it or just leave it open? anyone?
Old Jan 12, 2012 | 07:39 PM
NemeSS's Avatar
Loop it with hose. Don't leave open, don't cap off. Use hose clamps, 3/8 or -6 hose will work with the clamps
Old Jan 12, 2012 | 08:11 PM
FasTimeSS's Avatar
mine are two different sizes
Old Jan 14, 2012 | 10:21 AM
a-low's Avatar
I vote for a write up.
Old Feb 26, 2012 | 10:07 AM
30th t/a's Avatar
I vote for a write up too.
I want to make a set of lines for the rack and need to know what size fittings these are. Click on the picture to see what fittings im talking about.
Old Feb 27, 2012 | 08:13 AM
oldmano2z's Avatar
what do you lube it with?? the devils lube?? run a dry rack for drag racing?? just asking i'd like a manual rack myself for a daily driver
Old Jan 19, 2019 | 01:02 PM
Royce Thizzelle's Avatar
U will need
M16x1.5 to -6
M18x1.5 to -6
For steering rack
what size is the thread on the return line that goes into the rack
Old Jan 19, 2019 | 02:56 PM
You think he'll answer after 6-1/2 years?
