Power steering thread size
Old Jan 21, 2019 | 09:52 AM
01ssreda4's Avatar
Originally Posted by NemeSS
Less than a 100$ if I plan on running your route for lines for turbo/headunit clearance,etc.
I make my own lines when build hotparts. But I also use a different power steering pump and remote reservoir I came up with and eliminate the stock fbody ps pump.
Looks cleaner, more clearance, remote reservoir. Steel pulley, ps pump bolt access without removing pulley
I know this is old but since it was bumped I will add this:
https://ls1tech.com/forums/general-m...-easy-way.html
