Installing MS4 in 04 z06 without removing heads?
Don't you have to pull the heads off to replace the springs or is that the rocker arms you have to pull the heads of to replade?? Can someone post a link that shows how to replace valvesprings? I was using ms4 as a example. I was thinking a 228r or a vrx5 cam.. what else will I need to replace valvetrain wise? And should I just port my oil pump and get ls2 timing chain or does someone recommend anything else? Thanks for the input guys!!
Just take the heads off, 15 min of extra work. And you can work easier.. Get some arp head bolts and you can reuse them for the life of the car.. And that's a big cam, deff need springs and new lifters and the trunion upgrade..
I'd hate to put that cam in and brake a stock part on the engine and do major damage..
Just my opinion though!
This should work: http://www.ls1howto.com/index.php?article=23
Read Carefully
Read Carefully
LS1Tech Premium Sponsor
If you run into any trouble during the install, give us a call!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic211066_2.gif)
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Will the trex cam require any fly cutting to th pistons or milling to the heads period? Because I really don't want to have the car down for that long. And what about in a ls1?
#32
Wonderful! Now I understand everything 100% besides reinstalling the crank shaft pulley, now is he saying install the new longer one and torque it to 240lb/ft and you're done?? And what cam's are guaranteed to not stop the rotating assembly for being too big?? Thanks for the help!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#33
A trex will clear stock heads.. Not sure what you are asking about porting/milling the heads.
It doesn't take long to fly cut if you want to mill the heads.. I recommend it.
What about in a ls1? It isn't needed but plenty do it.
#39
DO NOT use a longer bolt to install the pulley. You need to push the pulley on not pull it with a longer bolt. You run the risk of damaging the crank threads. I built a tool that threaded into the crank and used washers and a nut to push the pulley back on. Hope that makes sense. ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#40
![](http://i194.photobucket.com/albums/z84/splitfinger09/Mobile%20Uploads/IMG_6052.jpg)
