Pacesetter Header Fitment Problems?
Old Mar 17, 2004 | 10:57 AM
SS GIRL's Avatar
Default Pacesetter Header Fitment Problems?
Has anyone had any fitment problems when putting on Pacesetter LTs?
Thinking about getting those...
Old Mar 17, 2004 | 11:02 AM
foff667's Avatar
LS1TECH Sponsor
you can check out my website in my sig for the install and notes i took on the install if youd like
Old Mar 17, 2004 | 11:06 AM
SS GIRL's Avatar
thank you how do you like yours? are they loud, raspy, what?
Tranzor's Avatar
I'm extremely happy with my Pacesetters!
Pacesetters fit very well, no exhaust leaks or anything. Just be sure to notch the k-member about an inch or so on the driver's side for clearance. The passenger side fits with no problems (basically just slides right in), and the driver's side goes in easily once you unbolt the steering linkage (only two bolts, much easier than grinding on the block tab).
Also, you'll want to use a pry bar to pull down on the y-pipe to give it a little space from the floorboard. Other than that, the y-pipe fits really nicely with the headers and the i-pipe...
You will also want to get some nice stainless steel 3" band clamps (they were $8.99 each at my local NAPA, and I needed four of them) because the U-clamps that the Pacesetters come with are terrible for getting a proper seal.
Old Mar 17, 2004 | 11:13 AM
foff667's Avatar
LS1TECH Sponsor
ssgirl hit me up on aim later and I'll send you a video or sound clip of friday when i was at the track...they are quite at idle w/ my open borla but at wot they scream though partly cuz of my converter...I'd recommend them over pretty much anything else out there.
Old Mar 17, 2004 | 11:22 AM
Nasty N8's Avatar
They are backordered now they are fixing the fittment issue.
Nate
Old Mar 17, 2004 | 11:24 AM
ss rally red's Avatar
I have installed 3 sets of these and never had to unbolt the steering linkage, on one car I had to grind off the tab on the block slightly, did get the band clamps from Napa also, best bang for the buck out there IMO.
Old Mar 17, 2004 | 11:49 AM
samz28's Avatar
did you experience some exhaust leakage before band clamps? I might have some of that on the ORY. Got a part # or good description of what ya got? Napa next the cowboy bar and ghetto hotel on 78?
Old Mar 17, 2004 | 02:30 PM
MadIceV8's Avatar
Customizing Director
No fitment issues with mine at all. I still need to buy some 3inch band clams to help seal the header and Y connection better. Plus it will get me a little bit more clearance compared to the cheep U clams. Do a search also, MANY topics on this.
Old Mar 17, 2004 | 02:41 PM
WS6 ON STERIODS's Avatar
You should spend the extra money for some qtp's or flp's.
