FAST 92mm intake manifold GASKET INSTALL?
Old 01-18-2012, 01:10 PM
3YLSYKR's Avatar
Default FAST 92mm intake manifold GASKET INSTALL?
I have been looking online for pics and info of how to route the gasket between the top and bottom halves on a 92mm FAST intake manifold but have come up with nothing.
I contacted FAST and they sent me a pdf of original install instructions and shows a crappy pic of gasket around out side perimeter but nothing over the humps or anything.
When I purchased a new gasket for it, they sent one big long tube and no instructions where it goes, starts, ends, layout nothing.
Fast is going to do some digging for me but wondering if anyone on here might know or have an idea of how to assemble the gasket and anything else I might need or to do so I can put this manifold together and use it.
Appreciate any help. Thanks.
Old 03-22-2012, 12:55 PM
3YLSYKR's Avatar
Anyone???
Old 03-22-2012, 01:02 PM
SSmoked1's Avatar
https://ls1tech.com/forums/generatio...-question.html
That thread has a couple pic's that might help..
Old 03-22-2012, 01:14 PM
3YLSYKR's Avatar
That helps a lot, thanks a lot for the help. Much appreciated. You rock.
Old 03-22-2012, 01:41 PM
99Bluz28's Avatar
It looks like you do the perimeter first, and cut it to length and put a dab of silicon sealant between where the two ends meet. I'm sure you do the same on the shorter pieces over the humps. FYI, don't stretch the seal when installing it.
As far as where you start/end the perimeter seal, just pick a straight section.
Old 03-22-2012, 03:17 PM
3YLSYKR's Avatar
That helps a lot too, thanks very much. I'm gonna go put it all together right now.
Quick Reply: FAST 92mm intake manifold GASKET INSTALL?
