Custom low budget cross ram intake
Old Sep 12, 2014 | 10:50 AM
  #41
Sarg's Avatar
Look forward to seeing the conclusion of this project. Very cool.
Old Sep 16, 2014 | 02:34 PM
  #42
lt170chevelle's Avatar
interesting
Old Sep 17, 2014 | 07:15 AM
  #43
smitty2919's Avatar
In for progress
Old Sep 21, 2014 | 10:16 PM
  #44
jlcustomz's Avatar
Got the runners tacked to the velocity stacks.
Disassembled to weld up.
Old Sep 21, 2014 | 10:20 PM
  #45
Sarg's Avatar
Love the ingenuity even if it drops a hp or two!
Old Sep 21, 2014 | 10:21 PM
  #46
AGearHead4Life's Avatar
awww yea!
Old Sep 22, 2014 | 12:50 PM
  #47
01ssreda4's Avatar
Cool project.
Old Sep 24, 2014 | 02:29 PM
  #48
Jacktuner's Avatar
Nice work, cant wait fir the results
Old Sep 26, 2014 | 04:49 AM
  #49
rkreigh's Avatar
looks like it will flow well
did you by chance see the OBX setup
it's 1200 which looks cheap for what you get!!
Old Sep 26, 2014 | 10:55 PM
  #50
jlcustomz's Avatar
Not aware of an obx manifold of any sort for ls engines, what are you referring to???
Progress report, I have the outsides of the runners sanded down &polished most of the way, still have hours of work on the insides of the runners. Almost ready to polish my 2nd set of plenums I've made.
Still barely started on 2 into 1 for throttle body. Need something for vacuum connections, throttle cable bracket & support for plenums, since runners connect to base with rubber connectors. Also need to add material to base & bottom of runners to make D-shaped area rounder for rubber connectors to seal. Lot left to do.
May mount throttle body upside down to not have cable running up top.
Kinda slows progress down when life keeps happening, like getting home from work 9:00 on Friday night. Eh
Old Sep 27, 2014 | 12:33 AM
  #51
1970camaroRS's Avatar
This is the OBX. Reports from others say that there are quality issues and the throttle blades like to stick when it warms up. http://www.ebay.com/itm/like/111466017517?lpid=82
Old Sep 28, 2014 | 09:18 PM
  #52
jlcustomz's Avatar
Got some welding & a little bit of polishing done. Sat the new intake on top of mine at a car show Saturday. Got a 2nd place modified class trophy. Funny how many people asked how the hood could close with that supercharger on top.
Old Oct 3, 2014 | 10:11 AM
  #53
smitty2919's Avatar
How do you plan to route pipes to feed the intake you made?
Old Oct 3, 2014 | 10:52 AM
  #54
jlcustomz's Avatar
Look at the picture in post #39. There is an aluminum pipe on the pass side. Will tack 2 together on center making a v looking shape running parallel with runners, enlarge area, & make plate on front to mount throttle body. Might put throttle body upside down to hide cable underneath.
I have the aluminum pipe tacked together for this, but may switch to stainless pipe like the runners because it shines & stays shiny so much better. Out of time to work on for now, but may still try to get done for Daytona turkey rod run.
Old Oct 4, 2014 | 04:19 PM
  #55
JS30612008's Avatar
Looks sick hope it turns out
Old Oct 8, 2014 | 07:15 PM
  #56
jlcustomz's Avatar
Out of time to work on for now ,pic from npd Silver springs show.
Old Aug 14, 2015 | 06:16 PM
  #57
1969honda's Avatar
Any word on how this all turned out? Looks pretty sweet for a low budget custom manifold, love the ingenuity!
Old Aug 17, 2015 | 06:00 PM
  #58
jlcustomz's Avatar
Still haven't been able to make time to work on it since last post. Currently reworking my tiny work area at home & ran new electrical power to bring my tig welder home.
Hope to get back on it next year & many other of my ambitious projects once I have a better home work area.
Old Aug 17, 2015 | 06:55 PM
  #59
1969honda's Avatar
Glad to hear you are still moving forward as you can, I know all about the small space/electrical issues. Currently saving to get 220 in to my garage but have to pull a bigger service drop and panel for the wife's ac first. Good luck with it and I'm sure we'll all keep an eye out for any updates!
Old Oct 30, 2015 | 11:10 AM
  #60
smitty2919's Avatar
Any updates on this? Will you have a before/after dyno sheet to show how well this works or not?
