Modified Intake Idea! Input welcome
Old Jan 27, 2012 | 06:42 AM
SweetS10V8's Avatar
Just a bit of info;
Ive tested a 102mm TB and a 75mm TB back to back on a 500hp LS engine. The difference was 5 fwhp across the board. Lets do quick math, 27mm difference, 5hp. 5/27 = .185hp per mm. Your looking at going 10mm x .185 = 1.85hp gain going from the 80 to the 90mm. This is all assuming your engine requires 500hp of air and your intake gains like the FAST does.
Like said above, the power is in the runners and not the TB opening.
Old Jan 27, 2012 | 03:35 PM
85CamaroZ28's Avatar
Anyone know if there is enough room to port it for an 85 MM tb?
Old Jan 27, 2012 | 06:21 PM
BaddBird's Avatar
Yes there is.
Old Jan 28, 2012 | 11:45 AM
firemech21's Avatar
My backup plan is to go with an 85mm throttlebody, but I can upgrade to a 92mm for less than $150. Seems like a simple decision to me and will give me something custom .
Old Jan 30, 2012 | 05:31 PM
firemech21's Avatar
Well Im waiting for the TB flange to arrive, but I have the new piece of pipe cut and ready to be put onto the intake. I am going in for a surgery tomorrow so I will be unable to do very much until I recover from that. For the throttle cables, Im going to trim around the bracket thats already on there and the new pipe will be welded onto them as well.
Old Jan 30, 2012 | 10:19 PM
squirlNUTZ's Avatar
I hope all goes well with your
surgery
Old Feb 1, 2012 | 06:28 AM
firemech21's Avatar
Thanks man, the surgery happened anyway and now Im in an unbelieved amount of pain. FML, it sucks.
Old Feb 3, 2012 | 02:03 PM
firemech21's Avatar
The mailman delivered a nice little part today. I have the intake cut and ready to go to the welders monday morning. The welder wants to mount the flange onto the original snout and then bore it out from there and it looks to have plenty of room.
Old Feb 7, 2012 | 02:25 PM
firemech21's Avatar
Today we were able to get the welds cleaned up a bit and also got the intake painted with VHT black wrinkle...
Old Feb 7, 2012 | 03:49 PM
firemech21's Avatar
BTW big thanks to Alex41 for all the assistance building this thing...
Old Feb 7, 2012 | 05:36 PM
hotrod388's Avatar
Nice piece of work.
Old Feb 7, 2012 | 06:32 PM
  #32
Alex41's Avatar
Not a problem bro.
Old Feb 7, 2012 | 07:09 PM
  #33
firemech21's Avatar
Thanks Hotrod388. Its definately been and interesting excursion cutting apart a perfectly good manifold.
Old Feb 7, 2012 | 07:12 PM
  #34
smg267's Avatar
Thumbs up
Hats off to you!!! I love seeing threads where people think outside the box. There are only so many" what cam?" threads a man can handle. Great work and execution!!
Old Feb 7, 2012 | 07:16 PM
  #35
hardcore4sure's Avatar
Interested in the results. The TPIS 90 Ls6 seems to get a solid 20rwhp over a stock LS6.
Old Feb 7, 2012 | 07:23 PM
  #36
99Bluz28's Avatar
So is the intake TB opening now 90mm or 92mm all the way into the intake?
Old Feb 7, 2012 | 07:39 PM
  #37
firemech21's Avatar
I havent finished cleaning the inside opening out yet. But currently the measurement is 89mm across and 91mm vertically. Im going to finish it to a 92mm opening all the way into the plenum.
Old Feb 7, 2012 | 08:11 PM
  #38
Blk98Vert's Avatar
How much would you charge to modify one?
Old Feb 7, 2012 | 08:14 PM
  #39
got milk??'s Avatar
That looks good and I guess you could take it all the way up to 96mm if you needed too.
Old Feb 7, 2012 | 09:26 PM
  #40
firemech21's Avatar
Blk98vert - shoot me a pm and we can talk about it.
96 does seem doable, who makes a TB that size?
