Wiring Help
Old Feb 2, 2012 | 05:13 AM
UrSmked's Avatar
Default Wiring Help
I need some help on identifying two harnesses that I didn't label when I pulled my motor and trans and now I am having a hard time figuring out what they are.
The first harness is located somwhere near the throttle body. It is a 2 prong male harness with a blue gasket. The wires are purple/orange or purple/tan, I can't really tell what color the second wire is.
The second harness is located right beside injector #5. It is a 2 prong male harness with a gray gasket. The wires are orange/pink w/ black stripe.
Thanks in advance for the help
Old Feb 2, 2012 | 01:47 PM
LS1MCSS's Avatar
First one sounds like the IAT plug. Not sure about the second one.
Old Feb 2, 2012 | 02:47 PM
TurboStangJON's Avatar
The first one (Purple and Tan wires) is the Intake Air Temperature Sensor and the second one (Orange and Pink w/Black Stripe) is the Secondary Air Injection (AIR) Solenoid. You probably have removed the AIR stuff off and now have an extra connector with no place to go.
Old Feb 2, 2012 | 08:00 PM
UrSmked's Avatar
Thanks for the information. I am going carburated, so I am trying to remove as much as I can. I just didn't want to start ripping stuff out that I didn't know what it went to.
