LS valve covers won't tighten
Old Feb 4, 2012 | 07:38 AM
383mazda's Avatar
Default LS valve covers won't tighten
Putting together my motor. I've got an LQ4 short block, got 317 heads off the craigslist and I am trying to use valve covers from a 5.3L I had sitting in the corner. When I tighten the 4 valve cover bolts down I can still move the valve cover around by hand (both valve covers do this, doesn't matter what side I put them on).
Valve covers have the gasket in them (stock I assume) and the bolts have the thick gray "washer" on them too - I cannot find anything about why these are not tightening down???
Any suggestions?
Old Feb 4, 2012 | 07:59 AM
Ls2 cruiser's Avatar
Are the bolts bottoming out in the holes in the head before the sleeves take up or are the bolt sleeves too long? You could trim the problem area the same on each and make them fit. The bolts and sleeves come apart by pulling the bolt upwards.
Old Feb 4, 2012 | 08:01 AM
Ronny_02_WS6's Avatar
It seems that they are short, Get some 6.0 (LQ4) 317 valve covers, I believe 5.3L are not compatible, or longer bolts.
Old Feb 4, 2012 | 08:39 AM
NVR_SPDS's Avatar
Can you torque the bolts to the stock spec? You may just need to replace the gaskets. Our valve covers dont bolt down flat. They are essentially spaced up to utilize the o-ring type of gasket.
Old Feb 4, 2012 | 11:00 AM
383mazda's Avatar
yeah, I have them down to stock specs, any tighter and I'm afraid I'd start to strip something, and the valve covers are no where near "seated" still.
I thought all LS valve covers (excluding the earlier perimeter heads) and valve cover bolts were created equal?
A shorter bolt or taller "gray washer" would work, but I'd like to find the real reason it's not working right...
Old Feb 4, 2012 | 09:18 PM
Track_FC's Avatar
Maybe those rubber spacers are shot. If they were smaller it would explain why the valve covers are floating.
Old Feb 4, 2012 | 09:43 PM
383mazda's Avatar
maybe... any idea what the "spec" height is on those spacers?
Old Feb 4, 2012 | 10:02 PM
3rdCoastPowerSports's Avatar
i don't think the rubber spacers are the problem. i have re used some really old and tore up valve cover bolts. I tighten them down to 106 in/lbs and there good to go. maybe someone swapped bolts on you. there are alot of really really dumb people out there you know.
Old Feb 4, 2012 | 10:08 PM
tooblue's Avatar
I would double check to make sure you do not have any Oil in the bolt holes. If the holes are full of oil you may not be able to get the bolts in far enough.
Old Feb 7, 2012 | 05:55 PM
383mazda's Avatar
I'll check for oil again, but the spacing / height of all the bolts is the same when installed (i.e. one bolt isn't down tight and the others are loose...)
Old Nov 30, 2012 | 08:32 AM
68wagon's Avatar
was there every any answer to this??? I just bought some Holley LS covers for my lq4 and i'm running into the same problem!!! the metal sleeve on the outside of the bolt is bottoming out before they get near tight enough.....
Old Dec 1, 2012 | 02:15 PM
383mazda's Avatar
No solid answer - I grabbed some vette heads at a swap meet fr a short block I have in the corner and I couldn't get the valve cover to seat on them either??? I'm going to cut the bolts shorter by a few threads - no sense in spending $4 a bolt from a dealership.
Old Dec 3, 2012 | 06:45 PM
Pocket's Avatar
Cut the sleeve down for your aftermarket valve covers and ignore most of those idiots above
If you stock valve cover isnt pulling down, check the gasket. The large O-ring gasket can flatten over time. If its not that, check for crap in the hole on the cyl head. Its a blind hole and if junk falls down there it has no where to go
Old Dec 3, 2012 | 06:50 PM
68wagon's Avatar
i went yesterday and bought new gaskets and i think that fixed my issue.. they tighten up nice now... i would have never thought the gasket would make that much difference...
By Brett Foote | 2026-06-04 05:00:17
