Porting TRUCK intake manifolds and throttle bodies!
Old 02-08-2012 | 04:54 PM
peakspeedshop's Avatar
Default Porting TRUCK intake manifolds and throttle bodies!
Peak Speed Shop now ports LS GenIII and Gen IV Truck intake manifolds and throttle bodies!
These stock manifolds are three pieces sonic welded together. They are plagued with ridges where the pieces join together. Porting removes those ridges and bumps to create better air flow through the manifold. Our car customers have found that having their intake manifold and throttle body ported by Peak Speed Shop has been one of the lowest cost per horsepower gained mods that they could make. NOW TRUCKS CAN BENEFIT, TOO!
JUST $250 for intake manifold porting. And..... only $75 additional to have your throttle body ported at the same time!
Plenum Opening before and after professional porting
Runner before and after professional porting
Simply place your order at our website: http://www.peakspeedshop.com/
Then, remove your intake manifold and throttle body and ship them to us for porting. We can generally turn them around and ship them back within 2-3 days.
For even more power, order a ported FAST manifold from us at http://www.peakspeedshop.com/
Or, call us at 719-651-1952.
Old 02-09-2012 | 02:13 AM
01ssreda4's Avatar
Work looks good
Old 02-10-2012 | 02:12 PM
Originally Posted by 01ssreda4
Work looks good: thumb:
Thankyou!
Old 02-15-2012 | 09:39 AM
to the top
Old 02-15-2012 | 01:26 PM
1989GTA's Avatar
Do you happen to have a single truck intake runner for sale? Maybe one that has a problem? I am experimenting with a SBC intake manifold and that runner seems to be a good one, so no reason to re-invent the wheel.
Old 02-15-2012 | 01:49 PM
JRENIGAR's Avatar
Any gains to be had on an ls6 intake if the tb is already ported and running 9lbs boost???
Old 02-15-2012 | 01:57 PM
Are you referring to the runners from a FAST truck manifold? I don't have them in stock, but I can order a set of 8 if you need them. Send me a PM if interested. If you're referring to a stock truck manifold, we don't have any junk ones on hand that you could tear apart.
Old 02-15-2012 | 02:02 PM
There is not much gain from porting the LS6 manifold. At this point, we don't do radical porting to the LS6. On the intake manifold side, your next step up would be to go to a FAST102 setup. You can go to our website at http://www.peakspeedshop.com/ to find pricing on a FAST102 system.
Old 02-15-2012 | 06:05 PM
1989GTA's Avatar
Yes the runner from the FAST truck manifold. I really just need one for mocking up purposes and seeing if I can make it work. Maybe I can get one from FAST. Thanks for responding.
Old 02-15-2012 | 06:24 PM
sepsis's Avatar
Nice! Does it come with a shoe horn?
Old 02-16-2012 | 12:53 PM
No shoehorn necessary.
Old 02-18-2012 | 10:49 AM
to the top
Old 02-20-2012 | 12:36 PM
to the top
Old 02-22-2012 | 12:39 PM
to the top
Old 02-23-2012 | 12:30 PM
to the top
Old 02-24-2012 | 01:13 PM
to the top
Old 02-24-2012 | 03:00 PM
1989GTA's Avatar
Do you happen to know the inside length of the FAST straight truck runner?
Old 02-26-2012 | 03:55 PM
underatedT/A's Avatar
does this include the tbss manifold?
Old 02-26-2012 | 09:10 PM
1989GTA's Avatar
That would be better yet. Then I would only have to add the head dimension. Just trying to get a ball park figure.
Old 02-27-2012 | 05:00 PM
I can see if I can get that for you. Are you wanting the short curve radius or the long curve radius?
Quick Reply: Porting TRUCK intake manifolds and throttle bodies!
