Help with parts numbers
Old Feb 8, 2012 | 05:16 PM
JeaneGrae's Avatar
Default Help with parts numbers
Fellas im looking for the part numbers for the ls6 valley cover and the coolant lines to swap the ls6 mani onto a 99.
Old Feb 8, 2012 | 05:38 PM
gMAG's Avatar
Here is the valley cover. Pls read carefully as there are two different part numbers.
http://www.z06vette.com/forums/f5/va...s1-ls2-111105/
Old Feb 8, 2012 | 05:41 PM
gMAG's Avatar
link to coolant lines with pic.
Pls stand by for part #....looking!
http://www.hawksthirdgenparts.com/98...offplates.aspx
from ls1howto.com
ls1 to ls6 intake manifold swap..
http://www.ls1howto.com/index.php?article=5
12568478 front coolant tube & 12562788 (2 rear plugs)
Hope this helps.
Old Feb 8, 2012 | 08:16 PM
JeaneGrae's Avatar
Default Valley cover
Thanks bro, the link for the valley cover wouldnt work. And will either work, or will i need one specifically.
Old Feb 8, 2012 | 11:04 PM
gMAG's Avatar
2001+ LS6 Engine Valley Cover (GMPN 12568002)
This can be verified on LS1HowTo.com "F-Body How To's"... LS1 to LS6 PCV conversion.
Old Feb 9, 2012 | 12:09 AM
sjsingle1's Avatar
^^^ old style cover.......requires PCV..........new style does not
Old Feb 9, 2012 | 12:19 AM
gMAG's Avatar
This is true. The redirect in the second post refers to this.
Here is the revision cover #12577927 from that post.
Not sure what the OP is looking for.
Old Feb 9, 2012 | 03:44 PM
gMAG's Avatar
Here is info from a post happening currently. The alternatives are discussed, although it's a bit confusing.
https://ls1tech.com/forums/generatio...t-numbers.html
