header removal help
Old Feb 26, 2012 | 11:35 AM
need4fun2469's Avatar
Default header removal help
I am removing my old ps headers and replacing them with tsp headers. I am having a problem getting the ds header out. I have a few questions:
1. how does the steering arm remove?
2. does the ds heat shield need to be reinstalled?
I will also be swapping out mm's for polys.
Old Feb 26, 2012 | 12:27 PM
any help would be useful as I am in the middle of this
Old Feb 26, 2012 | 12:36 PM
1BAD02WS6's Avatar
Have you removed the mm yet?
Old Feb 26, 2012 | 12:38 PM
omarrakeen's Avatar
steering arm was the easiest thing to remove when i did mine...there was like 2 bolts to loosen and the whole thing came out..there isnt a specific way to remove headers..just look around and take your time! good luck.
Old Feb 26, 2012 | 01:57 PM
Uneverknow's Avatar
Get the car jacked up high. So you can tip the header to the right angle.
Old Feb 26, 2012 | 02:55 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
17 1/2" is what i needed between the garage floor and the bottom of the K
Old Feb 26, 2012 | 03:18 PM
the front tube of the ds header is hitting on the steering shaft, not allowing it to pass. I unbolted the bolt closest to the firewall and the bolt closest to the steering rack. I cant get the steering shaft to slide.
Old Feb 26, 2012 | 03:19 PM
not yet. I need to get the ds header out first.
Old Feb 26, 2012 | 03:20 PM
when you undid the 2 bolts did the steering shaft slide?
Old Feb 26, 2012 | 03:22 PM
babbage1109's Avatar
Use a bunch of wd40. Put your key in so you can turn the wheel. Then Just pull up on the bottom of the knuckle until it comes off. It just takes elbow grease
Old Feb 26, 2012 | 03:23 PM
I will try it.
Old Feb 26, 2012 | 03:31 PM
It's notched. So it only goes on a certain way.
Old Feb 26, 2012 | 05:27 PM
01transampower's Avatar
The other problem you could be having is since you dont have poly motor mounts the stock ruber ones could of collapsed in a sence and the motor is now lower then before. you may have to unbolt the driver side motor mount jack the motor up and it should lide right out because with the motor jacked up you will have more clearence between the head and the stearing knuckle.
Old Feb 26, 2012 | 05:34 PM
I got the steering shaft off and the header out. Moving on to the mm's. I got the big bolt out of the ds mm, starting to work on the 4 clamshell bolts that hold them to the block.
when people put the ds header in, did you put the heat shield in or leave it out?
Old Feb 26, 2012 | 05:43 PM
Most people leave it out. I left mine out. It's not gonna cause any problems theres no wires running in that general area anyway. Make sure you use a sharp drill bit. Helps it go faster and a can of wd-40.. Drill press works great if you have one. I didn't have one so i have to do it with a drill almost broke my wrist one night drilling one of the holes since the bit was dull.
Old Feb 26, 2012 | 05:47 PM
I took off all of my heatshield besides the one actually protecting some lines under the driver floor
Old Feb 26, 2012 | 10:06 PM
I got the ds mm swapped out. I will start the ps next weekend. Maybe my arms will heal a little by then. It looks like a cat used my arms as scratch posts. lol
Old Feb 26, 2012 | 10:10 PM
Thanks for all of the reply's and help.
Old Feb 27, 2012 | 01:22 AM
omarrakeen's Avatar
EDIT: just saw that you took it off. glad it worked out
Old Mar 15, 2012 | 06:38 PM
I have both mm's in and bolted down with the headers installed. Now my tranny pan is leaking bad.
