TSP 1 7/8" and Plug Wires
Old Mar 2, 2012 | 06:46 AM
themealonwheels's Avatar
Default TSP 1 7/8" and Plug Wires
Is this going to be a problem?
Just the boot is touching, but it's clearly pushing the boot over. I have 8 heat boots/sleeves, but... well, I really like the color of these Granatelli wires with my setup Do I need to put wire boots/sleeves on these?
Oh, and the new 1 7/8" fit like a DREAM with a tubular k-member, as well if not better than my Pacesetters did!
Old Mar 2, 2012 | 07:30 AM
justin hover's Avatar
Ahh man..it might take awhile but I beleive they'll start to melt. You can always drive for a few hundred miles and check them.
But with them making contact already they'll absorb more heat, as oppossed to if their was a 1/16" gap in there.
Old Mar 2, 2012 | 07:43 AM
DarkFox118's Avatar
Hrmm, I was planning to get these headers for my project.
So what's the resolution if this is a problem? Different wires?
Old Mar 2, 2012 | 08:04 AM
trans_am7935's Avatar
MSD Super Conductor 8.5mm wires. they have bendable (shape-able) boots. you can bend them away from the header, only way to go! i have had them for 5 years now, and taken them off plenty of time, never had a failure or a problem with contacting the header
Old Mar 2, 2012 | 08:18 AM
I was afraid of that pretty expensive wires to test that on...
Yeah, I have MSD wires on my B4C and the boots are even angled so you can angle them away from the primaries. If that's not enough, they're bendable! But they're not available in blue
I have 8 of those heat sleeves for plug wires, but they would almost certainly rest on the primary anyway with these boots. Will they save the boots? Or do I have to go get black MSD wires to provide a gap?
Old Mar 2, 2012 | 10:43 AM
revtech101's Avatar
It should be okay. Slice the boots at an angle where it touches the headers if you have to.
Old Mar 2, 2012 | 11:30 AM
ISMELLRICE's Avatar
it will melt that piece you can zip tie them though lol or use a box cutter and shape them
Old Mar 2, 2012 | 12:29 PM
sjsingle1's Avatar
take off the heat shields and bend them......nuff sed
Old Mar 2, 2012 | 12:53 PM
Rickenbackerman's Avatar
I don't think you'll be able to bend those heat shields without kinking them. I'd take a razor blade and cut some of the boot off where it contacts. I don't think it'll hurt anything.
Old Mar 2, 2012 | 01:03 PM
I'm looking to see if the Granatelli boots are bendable, but did you mean bend the shields?
Hmm, cutting the boot certainly won't be difficult, but could I avoid this with the heat sleeves? I had two on before the TSPs, but only because the boot was really close to the flange... Supposedly they're rated to 1200DGF?
Old Mar 3, 2012 | 09:18 AM
mebuildit's Avatar
That's what I did. I put on Kooks 1 7/8 and was burning the stock plug boots. So I bought some MSD wires, and some high temp sleeves, and it fixed the problem.
Old Mar 3, 2012 | 09:49 AM
i know you like the blue color, but the MSD wires have also been proven to have the least resistance and the most efficient wire for out F-body cars. just FYI
you can always just paint them! or sleeve the wires with the blue outer of a bigger wire. the MSD's are only 8.5
Old Mar 3, 2012 | 01:22 PM
TImmy_Jones's Avatar
Just buy some wire protectors. Problem solved....forever.
Old Mar 4, 2012 | 06:55 AM
I took the stock metal protectors off and slid all 8 heat sleeves on, so time will tell. I didn't trim the boots, so this will be a sort of experiment to see just how effective these sleeves really are. I'll get some pictures posted tomorrow...
Old Mar 4, 2012 | 07:49 AM
Blk98Vert's Avatar
Sorry but that's wrong, they are 2nd to granatellis
Old Mar 4, 2012 | 10:14 AM
Rare96LT1Formula's Avatar
Just ordered the MSD's yesterday from a sponsor, hoping they will work with my Edelbrock LT's. Seems like alot of guys here run them without too many issues.
Old Mar 4, 2012 | 09:05 PM
MurderedOut's Avatar
Ran MSDs for 3 years and they still look brand new. Recently switched over to Taylor thundervolt 10.4 for my coil relocation kit. No difference even though theyre way bigger and a nicer wire.
Old Mar 4, 2012 | 09:36 PM
Deviant LS1's Avatar
If the boot is touching the header's it's going to melt. I would run the protective boots. If the boot is touching primary it's not going to burst into flames. It will how ever transfer the head through it and may still melt the wire a little.
Old Mar 5, 2012 | 06:57 AM
So here's what I did. I think it's a good compromise, but the boot wouldn't bend with slight force and I didn't want to risk breaking a wire because these things are a solid core. The sleeve is double layered, and it's much more substantial than the DEI sleeves at Autozone/Advance. It bends, but they're stiff sleeves so I feel a bit more comfortable.
What do you guys think?
Oh, and here's my clearance with Hotchkis springs and a TSP Y that I beat into place and probably could have spent more time adjusting for clearance... I'm happy
Old Mar 5, 2012 | 07:37 AM
ramairetransam's Avatar
wow that clearance i slow .
