Old May 5, 2016, 05:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Electrical Guides
Print Wikipost
Best Battery Replacement? Who Is Using What?
Old Mar 19, 2012 | 04:57 PM
bww3588's Avatar
Not true at all...your alternator is designed to run the entire electrical system after the vehicle is running. The battery simply holds a charge while the engine is off to start the vehicle and run the radio and **** while it is not running.
Once it is running, your battery is no longer a battery, it is a capacitor to prevent voltage spikes from entering sensitive computer circuits and causing power surges.
Don't believe me, get your car running and remove the positive battery cable...it will continue to run.
Old Mar 19, 2012 | 06:57 PM
Paul Bell's Avatar
That's MISTER MODERATOR
There was a thread where the guy from Optima was posting, fielding questions and setting myths and such straight.
I recall him saying that if a battery was stone cold dead, it would need to be charged outside the vehicle.
Regardless, I've always been able to bring them back with just the car's alternator.
Old Mar 19, 2012 | 11:54 PM
99Bluz28's Avatar
Well regardless, it's still not the best or correct way to recharge a battery.
Old Mar 20, 2012 | 08:27 AM
udienow's Avatar
I just got the "gold" whatever from my local auto parts store. Its got I think a 3 year replacement warranty so thats all I really care about... dont have to spend a dime if it goes out. I think you get a 3 year warranty with Optima as well but they cost a little more. Last year I forgot to unplug the battery during winter storage and I guess it got drained so bad it wouldn't take a charge... this was a 1 year old battery... lucky for me i got a replacement for free.
Old Mar 21, 2012 | 03:04 AM
baxsom's Avatar
my 68 mustang, 72 vette, 00 vette, and 03 ford explorer all use the same model wal mart battery. replaced them all a few years ago and even the old cars which get cranked just a few times a year fire right up every time.
Old Mar 21, 2012 | 08:19 AM
Flawless02SS's Avatar
Die Hard Gold here with float charger. My car sits for months at a time and starts up like I drive it everyday.
Old Apr 18, 2012 | 04:42 AM
01ssreda4's Avatar
Originally Posted by mebuildit
Braille batteries
I've been looking at lightweight replacements and the brailles look they are nice performers.
Old Feb 23, 2016 | 06:20 PM
ExtinctBird's Avatar
I know this is an old thread, but I am very impressed with my energizer battery. I have never had it on a tender, and the car sits all winter in a garage or under a cover. Year after year the car starts right up without issue. I cannot remember when the battery was put in, but it had to be at least 10 years ago.
Old Feb 23, 2016 | 06:47 PM
kingtal0n's Avatar
While this may be technically true, I've jump-started many cars with dead batteries and in time, the car fully charged the battery.
This places a large, unnecessary load on the alternator, may wear the alt out more quickly, and it may affect the lattice of the battery's internal solid components over time.
If you discharge two different battery several times, and fill one back up using an alternator, and the other using a high quality charger, the one that gets charged with the charger may last longer.
Old Feb 23, 2016 | 08:05 PM
Paul Bell's Avatar
Originally Posted by kingtal0n
This places a large, unnecessary load on the alternator, may wear the alt out more quickly....
There's nothing electrical to "wear out" an alternator. It will only put out it's rated current.
While this is true, I don't think batteries are often taken down to stone cold dead. Maybe once in the life of a battery?
A properly functioning battery can be brought back to full charge from stone cold.
When somebody has a dead battery (they left their lights on or something) you give them a jump start and tell them to drive the car without shutting it off for a half hour. That's enough to get enough charge to start the engine.
Old Feb 23, 2016 | 08:24 PM
jimmyblue's Avatar
Moderator
Two AC Delco (OE type) batteries in a row leaked out
the side posts and chowed my positive cable connector.
Had good service from AutoZone "Duralast Gold" since.
Old Feb 23, 2016 | 09:22 PM
  #32
01ssreda4's Avatar
ooooooooo I was about to pounce! Glad someone caught that.
Old Feb 23, 2016 | 10:44 PM
  #33
Paul Bell's Avatar
Optima and ACDelco isn't what they used to be. Interstate MegaTron Plus are very highly rated batteries.
After exhaustive research, I got this group 65 bad boy for the Monte. 850CCA.
Old Feb 26, 2016 | 06:45 PM
  #34
kingtal0n's Avatar
You are telling me that if I have two alternators, and I run one constantly at full capacity, and the other at barely a trickle of output, they will both have the same life expectancy? I find it hard to believe.
Well, there is your caveat. You can get away with it... once or thrice~. But do not expect to fully charge a stone dead battery every single day without some loss of function.
Old Feb 26, 2016 | 08:52 PM
  #35
Paul Bell's Avatar
There are rotating parts in an alternator that wear regardless of electrical load on the alternator. Bearings & brushes. After much use over time, these parts will wear and fail. Again, with or without electrical load.
A well made alternator has quality coils wound properly and a matched rectifier set. All electrical items today have a power supply with rectifiers to convert to DC voltage. Rectifiers are semiconductors that have no moving or wear parts and don’t go bad from normal use. Rectifiers don’t care if their electrical load is light or heavy. How many items do we own that have rectifiers in them that last for years, even decades?
Yes, alternators do go bad-but not from using them more heavily than normal. If they did, they would blow up when you turn on your air conditioning, headlights, seat heaters, window defroster and wipers at the same time with radiator fans running while stuck in traffic at in-gear idle speed.
Putting a heavy load on an alternator will not shorten it’s life.
Exactly how many times do you totally discharge your car battery to stone cold dead status?
Old Feb 26, 2016 | 10:53 PM
  #36
Majestic9C1's Avatar
I use an AutoCraft Gold 75 series I got from work along with a 145A Silverado alternator and Innovative Wiring 1/0 gauge cables
Old Feb 29, 2016 | 08:10 AM
  #37
truckdoug's Avatar
i read good things about those interstates. i'll probably do one of those next time. supposedly made by johnson controls here in the states.
i also hear that optima's quality has gone down in the last couple years. that's kind of a bummer.
also interested in a normal size but lightweight agm, but i cant find one that fits the bill just yet
Old Feb 29, 2016 | 12:32 PM
  #38
NemesisC5's Avatar
Before I'd spend top dollar on Optima I'd get a Braille, Odysey or other lightweight battery and drop 20+ lbs. That's an easy weight savings on a necessary component. Roadrace, autocross, HPDE enthusiasts do it often...I'd think every little bit of weight you save increases performance by some small margin.
Old Feb 29, 2016 | 03:33 PM
  #39
kingtal0n's Avatar
Thanks for taking the time to respond and helping me understand what is going on, I have taken your information to heart and will use it in the future.
Old Feb 29, 2016 | 10:04 PM
  #40
NemesisC5's Avatar
Two popular lightweights, I'd guess we have a supporting vendor that sell at least one of these two.
https://www.braillebattery.com/index...atteries/b3121
http://shop.odysseybattery.com/p/pc9...ersports?pp=25
