How do you adjust set screw on TB?
Old Mar 17, 2012 | 12:08 AM
VandykeT/A's Avatar
Default How do you adjust set screw on TB?
I had my LS6 and ported TB on my cammed car for awhile and I adjusted the set screw up some to try to cure some idle issues (probably wasn't a good idea). Now that its on my bolt on car I've got a little bit of a high idle. For a while I thought I just had a vaccumm leak from swapping intakes but 3 cans of starter fluid later I'm convinced I don't have a leak. The car idles fast. Sitting still it will fall back to the 800 ish position but driving along and just throw the clutch in it doesn't want to drop below 1500 rpm sometimes. Its high enough sometimes when you let the clutch out at low speeds you can feel the car pull forward slightly. I tried adjusting the screw back down but I'm sure its not where it was. How do I go about setting it back to factory?
Old Mar 17, 2012 | 01:11 AM
99Bluz28's Avatar
Did you do a tps reset?
Old Mar 17, 2012 | 03:09 AM
01ssreda4's Avatar
^^^yep, gotta do that.
Old Mar 17, 2012 | 11:53 AM
VandykeT/A's Avatar
No I didn't do a tps reset. I'll search on TPS reset after I do that what do I do?
Old Mar 17, 2012 | 12:45 PM
99Bluz28's Avatar
Do this before starting car up.
Unplug the tps, put key in ignition and turn to the run position (don't start car), wait about 30 seconds, turn key to off position (remove key), plug tps connector back in, start car up and let idle until up to full tempture.
Old Mar 17, 2012 | 01:01 PM
99Bluz28's Avatar
If you still have the high/hanging idle issue adjust the set screw 1/2 turn to close up the tb blade a little more. Now do a tps reset again, repeat until issue is gone. If for some reason you go to far and 1/2 turn seem to be to much, then turn the set screw back 1/4 turn, and do a tps reset, again.
Old Mar 17, 2012 | 01:43 PM
VandykeT/A's Avatar
Ok the car was at a body shop getting painted for about 4 monthes. What little I've drove the car since it doesn't seem as bad. I hooked my diablosport to it to check codes last night and I only had the normal EGR, rear 02, and fuel sender codes. Now this morning I checked it after doing the reset and I'm getting a P0122 TPS low voltage code. What would cause this? Could it be from the reset?
Old Mar 17, 2012 | 02:51 PM
99Bluz28's Avatar
That or from when you adjusted it before.Did you go ahead and clear them with your Diablosport ?
Old Mar 17, 2012 | 03:03 PM
VandykeT/A's Avatar
Yea I cleared them while the car was running. The only thing that instantly came back was the EGR. I haven't moved the car out of the driveway since. It seems like it idles lower but the only real way to tell is driving it. Would the TB need to be in a exact spot to be right or will the reset allow it to adjust as it needs to keep the idle right?
Old Mar 19, 2012 | 11:55 AM
jimmyblue's Avatar
Moderator
The only thing you want from the set screw is to prevent
the blade from pulling into bind against the throat wall at
high vacuum, closed. So back it out, let the blade snap
shut, and then turn the screw in until you just feel the
blade respond, barely.
Old Mar 19, 2012 | 01:42 PM
VandykeT/A's Avatar
The way its set now it doesn't bind any. It idles perfect after the TPS reset. Thanks.
Old Mar 19, 2012 | 08:34 PM
jim ravencraft's Avatar
Hi,
Another little tip! Often times the cable on the tb can need some help with issues similar to yours. Tuning as you know, is very important for maximum gains and performance. Have a blessed week.....Capt. Jim
Old Apr 6, 2012 | 11:51 AM
VandykeT/A's Avatar
Ok this problem came back. No code but still the high idle. If I just adjust the set screw until it hangs, then go slightly forward and do a tps reset I should be good right?
Old Apr 6, 2012 | 12:22 PM
99Bluz28's Avatar
I'm going to say go with the suggestion jimmyblue gave. If it reverts to stalling again start open it up 1/2 turn, tps reset, and repeat if necessary.
Old Apr 6, 2012 | 12:56 PM
99Bluz28's Avatar
Just realized, you can use your Diablo Predator to help you set the throttle position. First completely back off the set screw(no contact), then do a tps reset. Now hook-up your predator turn the key to the run position(don't start it) and let it boot up, and then select the Diagnostics menu. Then choose the Real Time Data menu, then scroll down through the list until you see throttle position %, it should read 0%. Now go adjust the set screw until it just reads 2%, not any higher. Lock down the set screw, disconnect your predator,and do a tps reset again. I did this with mine without having any hanging idle/stalling issues.
