Throttle Body to go with PP 96mm intake?
also i know the ls2 throttle body is electronically controlled, but ive seen plenty on ebay, amazon that were cable driven....im not trying to be an ******* im just trying to get a feel for what the best TB is for my particular intake...i found a 92mm TB by Godspeed on amazon and i would port it out to 96 to port match the intake...ive just never heard of the company...i just want a reputable throttle body the ls2 guys use, other then the oem one
none with my 85mm one, other than I didn't like the
draw length needed to pull the throttle cam they
supplied and reworked it to get more angle per inch.
As far as seating, IAC function, TPS readings etc. it
was all fine.
There's "issues", and there's "issues". If I can fix them
with a drill and a rat tail file, I don't worry about those.
The throttle body I have heard does not have great flow, and i dont recall where i read that which is why i was looking into a different TB. but if you say that the PP is good ill take your word for it
i guess ill probably just run the PP 85 mm TB or ill get the godspeed TB
