Help slp pulley stuck
Old Mar 18, 2012 | 11:43 AM
Uneverknow's Avatar
Default Help slp pulley stuck
Ok I took my stock crank pulley off no issues got my slp pulley on but now I need to get it back off but I can't get it to budge.whats the deal
Old Mar 18, 2012 | 01:11 PM
Uneverknow's Avatar
No one.
Old Mar 18, 2012 | 02:52 PM
Uneverknow's Avatar
I just dont see why. what would be holding it up.
Old Mar 18, 2012 | 08:05 PM
S10xGN's Avatar
Uhhh, what tools are you using?
Old Mar 18, 2012 | 08:26 PM
redbird555's Avatar
this^^^ if your using a crank pulley bolt to pull it on then you may not be applying enough torque however you could also strip it out. either get the correct pulley install tool or go take the pulley off and heat it for 30 mins in the oven at 225 degrees. take it out with oven mits and it should literally slide right onto the crank with no problems.
Old Mar 18, 2012 | 08:47 PM
2xLS1's Avatar
He is trying to take it off.
Old Mar 18, 2012 | 09:55 PM
Bramlok's Avatar
You'll need a puller like this to get it off.
Old Mar 19, 2012 | 12:46 PM
redbird555's Avatar
DOH! It's been a long day lol.
Some people have used this with good results on the slp but I believe slp recommends using the chrysler puller available for rent from autozone to get it off the easiest
Old Mar 19, 2012 | 01:12 PM
Fafonfoe's Avatar
I had the same problem with the SLP the tool shown is correct. Put the three bolts in the pulley and use a socket to after the crank bolt is off and put the socket in its place to used as a extension and it will work perfectly. I've pulled mine off a few time with no problems.
