lingenfilter EGR adapter for LS6 intake.
Old Mar 23, 2004 | 07:01 PM
slow's Avatar
Default lingenfilter EGR adapter for LS6 intake.
where is it on thier site?
i looked, with no luck
Ryan
Old Mar 23, 2004 | 07:03 PM
M6HuggerSS's Avatar
i was wondering if there was a way to do it yourself? whos got the info?
Old Mar 23, 2004 | 07:04 PM
slow's Avatar
i found it....
they call it CNC ....
looks like they machine it out of a old LS1 intake.... ummm.....
Ryan
Old Mar 23, 2004 | 07:10 PM
M6HuggerSS's Avatar
any pics or links?
Old Mar 23, 2004 | 07:17 PM
DARK AGE 53's Avatar
Old Mar 23, 2004 | 11:14 PM
angst911's Avatar
$149.95
LPE has developed this CNC machined EGR adapter block to allow you to install a 2001 LS6 intake on the 1998-2000 LS1. This block is made from the same type of material as the OE intake manifold and is easy to install. Includes special adhesive and instructions.
looks like you could cut out a section from a stock intake, and have someone plastic weld it into a ls6......
Old Mar 24, 2004 | 05:23 AM
more carbon's Avatar
if anyone needs one i have it kickin' around the garage,100 takes it away.thks.
Old Mar 24, 2004 | 06:58 AM
99 Black Bird T/A's Avatar
Wow, this thing has really increased in price over the last two years. I paid ~$85 for mine from LPE in 2002. It was nicely done and fit well.
We used mine a little differently than intended. Just tacked in in place hooked up the EGR for the stock LS1 intake look used a block off plate and took care of EGR with tuning. No worries about leaks or risk damaging an LS6 intake drilling for the adapter.
Sounds like their is finally a use for LS1 intakes...cut the EGR adapter out...it will sell for more than the LS1 intake
Old Mar 25, 2004 | 09:10 PM
lsx24's Avatar
Lol!
Do you have any pics of the block off idea? That sounds like a great solution if you have edit.
Old Mar 25, 2004 | 09:36 PM
angst911's Avatar
so you say you block off EGR, using this and a blockoff plate, and made it so it looked like there was still EGR for a visual inspection???
Old Mar 26, 2004 | 07:44 AM
Angst911,
Yes, that is exactly what we did. I've had folks say, hey you need to get an LS6 intake when the look at the engine. I'll take a few pictures of the set up this weekend and post them in the thread.
Old Mar 26, 2004 | 10:09 AM
slow's Avatar
ummm..
That might be the ticket.
I will be getting hp tuners later so the code is not a problem.
the "oem apprearance" is the key though
(but that will go out the window, when the blower goes on )
Ryan.
Old Mar 27, 2004 | 10:12 AM
Will try to get a picture up tonight...if you promise not to make fun of my dirty engine compartment.
Old Mar 27, 2004 | 06:52 PM
lsx24's Avatar
Lol, can't be worse than mine.
Old Mar 28, 2004 | 08:13 PM
Default LPE adapter attached to LS6 intake for visual
Installed on T/A's LS6 intake.
Here's another two pictures.
Attached Thumbnails lingenfilter EGR adapter for LS6 intake.-dscn0249.1.jpg   lingenfilter EGR adapter for LS6 intake.-ghg.jpg
