LS6 Valley Cover
Old Mar 26, 2012 | 08:47 PM
hcb1700's Avatar
Default LS6 Valley Cover
Guys, I just ordered an LS6 valley cover. I have a question. I noticed that there's a ground strap on the original pcv hose, what is that for? Also, what is the part number for the pcv plug that goes in the valve cover? I'm a little scared of cutting a piece of the block, but I'm going to have to do it. Part of the reasons why I ordered it is because I broke my original hose, and figured this would be cheaper and faster to do. I should be getting it tomorrow, so I'll start the install right away.
Old Mar 26, 2012 | 09:43 PM
NVR_SPDS's Avatar
I just removed the PCV valve all together when I installed my LS6 valley cover. Did you get the old style, or new style cover?
The plug number should be GM Part # 12568011
In case you havent seen it, heres a how-to with part numbers: http://www.ls1howto.com/index.php?article=18
Old Mar 26, 2012 | 10:15 PM
hcb1700's Avatar
I got the new style withe the double 7 part number.
Old Mar 26, 2012 | 10:25 PM
gMAG's Avatar
Not to worry about the cutting. Just make sure you stick some rags in there to control the crud from the cut.
About 2 mos ago, someone else asked about that strap.
Here's a related thread.....
https://ls1tech.com/forums/generatio...pcv-valve.html
Old Mar 26, 2012 | 11:28 PM
sjsingle1's Avatar
its not a ground strap......its a heat transfer device.....keeps the PCV from freezing
Old Mar 27, 2012 | 07:44 AM
HoLLo's Avatar
Don't be afraid to cut the block. I installed the 04+ LS6 valley cover almost 2 years ago. I cut it a very simple way, I was actually able to get a fullsize hacksaw in there to cut the block and it cut through like butter. Then took vise grips and locked onto the cut and snapped it off.. Far less metal shavings than a cutoff wheel. I had rags stuffed in there and spent plenty of time vacuuming it out. Almost 2 years later car is still running strong.
Old Mar 27, 2012 | 12:04 PM
hcb1700's Avatar
Thanks for all your help guys. I'm waiting for FedEx to drop the cover off right now.
Old Mar 27, 2012 | 06:16 PM
hcb1700's Avatar
Well, I finally received the cover. I also called my local Chevy dealership and ordered the pcv plug,mans the tube. I will start the instal tomorrow, wheather Permit, and try to get as many pics as possible.
Old Mar 27, 2012 | 07:23 PM
HoLLo's Avatar
Also, good chance to replace your knock sensors and wiring harness since they have to come off anyway. And put some RTV sealant under the knock sensor boot to seal it back up.
Old Mar 27, 2012 | 07:34 PM
hcb1700's Avatar
Will do. Thanks for the advice.
Old Mar 27, 2012 | 09:08 PM
hcb1700's Avatar
Here is a pic of the cover, and the engine it will be going on. It's for my 2000 Camaro. It had a blown head gasket, so I replaced them, added a pair of 241 heads that came off of my brothers (30,XXX miles) '01 Z28, and added LS7 lifters as well. I'll also be adding an aftermarket PS cooler, and doing the throttle body coolant bypass mod to it. A transmission oil cooler is also in the works.
Old Mar 30, 2012 | 12:23 AM
hcb1700's Avatar
I finally installed the valley cover, but didn't finish putting the car together because I broke the oil pressure switch when I was installing the intake. Word of advice for those looking to do this, get the ls6 steam tubes. It was a pain trying to figure that thing out, that's the reason I broke the oil switch.
Old Mar 30, 2012 | 12:24 AM
hcb1700's Avatar
I'll post pics tomorrow.
Old Mar 31, 2012 | 06:49 AM
6t7gto's Avatar
Does this procedure eliminate needing a catch can?
thanks,
david
Old Mar 31, 2012 | 09:21 AM
HoLLo's Avatar
Still a good idea to run a catch can, but when I installed an ls6 valley cover I went from adding a whole quart between oil changes to not a drop lost.
Old Mar 31, 2012 | 09:30 AM
6t7gto's Avatar
Thx HoLLo
Old Mar 31, 2012 | 02:28 PM
ZQ8LS1's Avatar
Can you run the hose from the cover straight to the intake or do you need the pcv valve ??
If yes... what did you do for a pcv valve ??
Old Mar 31, 2012 | 08:06 PM
hcb1700's Avatar
This cover has an internal pcv system, so I just went and ordered the correct hose from my local Chevy dealer. I'll post pics later.
