Please Quick Help TRAP DOOR METHOD
Old Mar 29, 2012 | 09:54 AM
needtransam's Avatar
Default Please Quick Help TRAP DOOR METHOD
I know their id many guides out their but their was one really good one that gave you the dimensions on how to cut it
Also was wondering if any of you actually made the trap door a door? With hinges and lock?
Old Mar 29, 2012 | 11:20 AM
dodson55's Avatar
what kind of trap door you talking about some more info would be nice
Old Mar 29, 2012 | 11:24 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
He means to change the fuel pump.
I think the measurements are a bit different for a 98 vs a 99-02
Old Mar 29, 2012 | 11:32 AM
strokerrace's Avatar
What year? I can measure mine when I get to work if u want
Old Mar 29, 2012 | 02:13 PM
mine is a 2001 so 99-02 should be the same thanks guys and yes the trap door for the fuel pump sorry
Old Mar 30, 2012 | 10:07 AM
anyone?
Old Mar 30, 2012 | 11:19 AM
ICRAZY6's Avatar
Look in the fuel section.
Old Mar 30, 2012 | 02:51 PM
01ssreda4's Avatar
No need to measure, you just cut between the two center ridges, start from the rear and go about halfway to the front.
Old Mar 30, 2012 | 03:53 PM
the thing is that I want to make an actual trap door thought, with hinges and some kind of locking mecanism but clueless on how?
Old Mar 30, 2012 | 05:37 PM
need4fun2469's Avatar
get a piano hinge from the hardware store and glue a magnet or use velco to keep it closed.
Old Mar 30, 2012 | 10:15 PM
01ssreda4's Avatar
Buddy just came over and did mine for me and he cut 3 sides and peeled the panel back. During reassembly he drilled two holes just to the outside of the cut panel and we took 2 pieces of sheet metal and drilled holes in them. He then riveted the sheet metal to the body panel holes. The top riveted pieces will swivel over the panel to hold it down or swivel out of the way quickly to pull the panel up for access. We sealed it with silver foil tape to act as a vapor barrier. Quick and easy process that works very well.
Old Apr 5, 2012 | 03:27 PM
any pictures???
Old Apr 5, 2012 | 04:25 PM
mike171562's Avatar
I can see the hinges, but why would you lock it?
Old Apr 5, 2012 | 09:20 PM
sjsingle1's Avatar
be a man and drop the tank
Old Apr 5, 2012 | 11:10 PM
01ssreda4's Avatar
Originally Posted by needtransam
any pictures???
I didn't snap one but the carpet is still pulled up so i might as well. I'll post one here tomorrow.
Old Apr 6, 2012 | 08:29 AM
moeZ28's Avatar
My old car had a huge trap door cut in it by the previous owner...it was something like 16"x16"! Then they recovered it by putting a big sheet of 3/16 steel, not even aluminum, over the hole and used black gasket maker to seal it around the edges...it was way too big. Thats a nice sized hole there, still able to get things done and not monstrous like mine!
Old Apr 6, 2012 | 09:44 AM
MattxFatal's Avatar
I actually JUST did mine.
Can post a pic tonight to give you an idea.
The picture above IS NOT the way you want to cut, that's for the metal tank.
I only had tin snips and a drill.
I drilled some pilot holes and cut along them.
I didn't want to risk nicking some wires.
Then I sealed with RTV and SS.
Came out really well.
Depending on the way you're going to seal it, you may not want to cut all the way out to the ridges.
I left about half an inch so my RTV would have a useable surface when I sealed it up.
Old Apr 6, 2012 | 09:53 AM
ANTICOP RAM AIR's Avatar
That way nobody can steal your pump, duh...
Old Apr 6, 2012 | 10:12 AM
Adam86's Avatar
I just used a hunk of stainless for the door and used some self tapping screws to hold it in place. I also put some thing rubber stripping on the stainless piece where it meets the car.
Old Apr 6, 2012 | 01:22 PM
Thanks everyone and yes I need a 99-up for the plastic tank mine is an 02, im just wondering what exactly to put, im not too familiar with hardware so Im not sure what to ask for in lowes or home depot? some pictures of yours guys cars with the trap door would really really help and you would help a fellow ls1tech member
