98 ls1 pcv system pieces.....?
We need that little "y" rubber connector piece, what is that and where can I get it?
PCV Y Repair
The 3/8" divider I purchased was this one:
3/8" Two way
Then just go to your local auto store and get 2 feet of 3/8" inner diameter fuel or emission hose and replace all of it on your car. At autozone here you can buy a package with 2 feet of 3/8" emission hose for a couple bucks. It hangs next to the rack with all the pcv valves.
I'd suggest replacing your pcv valve while you're in there considering how cheap it is. Here is the style GM recommends to use now: PCV1009DL Don't use the one the computer suggests for your car, use that new style. They're entirely different on the inside.
I did this and my pcv system is 100% sealed.
PCV Y Repair
3/8" Two way
I did end up getting something rigged up and it functions now though! That being said, I'm going to go buy that "y" piece that you have a link to and replace the "t" I used with it. I don't like the extreme angles I ended up with. lol PCV Y Repair
3/8" Two way
