Crank bolt?
Old Apr 29, 2012 | 08:31 PM
dmracing's Avatar
Default Crank bolt?
Whats the easiest way to remove it. Ive tried an impact and breaker bar. Any tricks?
Old Apr 29, 2012 | 08:35 PM
fastazzls1's Avatar
impact gun is brave move lol if it didnt get it out you may need a breaker with a big cheater pipe
Old Apr 29, 2012 | 09:12 PM
s346k's Avatar
i stuck the breaker bar against something that would not break and bumped the engine starter. worked like a charm.
Old Apr 29, 2012 | 09:14 PM
arthropraxis's Avatar
Genius.
Old Apr 29, 2012 | 09:23 PM
01transampower's Avatar
I used the air impact it took about 20-30 seconds before it spun off just holding the trigger down had no problems. Makesure with the breaker bar have a friend and a heavy duty socket. I snapped 2 of mine.
Old Apr 29, 2012 | 09:40 PM
Grimes's Avatar
breaker bar with a 4ft pipe will do it.....
Old Apr 29, 2012 | 09:57 PM
boostit5.3's Avatar
the starter trick is the easiest, impact or a cheater pipe should work.
Old Apr 29, 2012 | 10:01 PM
Gray86hatch's Avatar
get a bigger impact.
if you are using the starter you are asking for problems.
Tim
Old Apr 29, 2012 | 10:03 PM
fastazzls1's Avatar
make sure you get a new bolt
Old Apr 29, 2012 | 10:23 PM
JTblack02SS's Avatar
i used a breaker bar with a pipe, took a little effort but i was being careful. came right out
Old Apr 29, 2012 | 10:46 PM
mcdonald77's Avatar
same here!
Old Apr 30, 2012 | 05:04 AM
sheaadams86's Avatar
I put mine in gear on the ground and pulled e brake, broke loose with breaker bar
Old Apr 30, 2012 | 08:01 AM
MT0911's Avatar
Make sure your e-brake is up tight and put the car in 4th gear. I used a 25" breaker bar and it worked just fine!
