P0306 Cylinder 6 Misfire!
Old 05-22-2012, 10:48 AM
1ltcap's Avatar
Originally Posted by BIGDATOWN
Yes the number sounds high, but it could also be the cam degree that makes the cranking compression higher. This compression number is perfectly fine for these motors.
that's fine.......i was just bringing it to your attention.
Old 05-22-2012, 11:45 AM
sprayedenali's Avatar
id say your best bet is to put about a 250 shot on it and let it eat until you find the problem!!! hell, the nos might even make it show up sooner so you can know what it is fatser and get it fixed!!! good luck!
Old 05-22-2012, 11:52 AM
BIGDATOWN's Avatar
If your donating the 250 shot mitch then I'm all for it! lol
Old 05-23-2012, 07:40 AM
01transampower's Avatar
The maf going bad will also cause a misfire. Mines going bad right now and throwing a P0103 number. Next would be the code your showing. Caused my the maf going bad or out. I'd check that too and replace it.
Old 05-23-2012, 07:43 AM
1ltcap's Avatar
maf's will generally cause lean codes before misfire codes.
Old 05-23-2012, 08:11 AM
BIGDATOWN's Avatar
And mafs will not cause low compression on a individual cylinder.
Quick Reply: P0306 Cylinder 6 Misfire!
