Thoughts on These Injectors?
Old May 16, 2012 | 03:26 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Default Thoughts on These Injectors?
** Had this in the fueling section (deleted) and it went unnoticed so I thought I would post it here for people that are "in the know" **
Bosch # 0280155759
Are these the same as "Red Tops" or are they a new design? I know they are 36# @ 58psi.... Just wondering if anyone has run this particular injector and what their impression was on a cammed car.
NO N2O on my car, and no plans, so I don't see the need for a 42#.
I can get 8 for 115 shipped.
Thanks for the thoughts and advice, guys.
*** EDIT***
Got part # 0280 155 811 from a Supercharged Pontiac. I believe they are 42lb @ 58psi, and White colored.
Old May 16, 2012 | 05:37 PM
99Bluz28's Avatar
I'm not 100% sure, but that really looks like what I just sold.
http://boschdealer.com/images/0280155759.jpg
BTW, I was at about 86% duty cycle when I had 36lb injectors in mine at 423rwhp.
So I'd still recommend the 42s, over 36s..
Old May 16, 2012 | 05:55 PM
dr_whigham's Avatar
The Scammer Hammer
Yes indeed, those are the exact ones I'm looking at right now.
86% with heads and cam? Damn
Old May 16, 2012 | 05:58 PM
99Bluz28's Avatar
Yeap, And my cam is only a 227(.614")/231(.617") 111lsa with LSL lobes.
Old May 16, 2012 | 07:01 PM
dodson55's Avatar
i had the red tops in mine and was at 90% duty cycle if your going to upgrade go strait to 42
Old May 17, 2012 | 07:05 AM
dr_whigham's Avatar
The Scammer Hammer
Well ****! I thought the 36's were good for like 500 to the wheels?
Old May 17, 2012 | 09:15 AM
dodson55's Avatar
id say they are good to around 500 flywheel without straining them to hard they probably could do 500 rwhp but you would be using every drop they could provide i was checking my duty cycle with hptuners my stocker were still giving fuel at 117% but at 120% they stopped providing more fuel im not sure how thats possible i went to the red tops and was around 90% and switched to green tops i am at 71% rite now but since injectors are rated to only opperate to 80% duty cycle safely i wonder if hp tuners runs there 20% off so that when it reads 100% the injectors are acctually at 80% because i thought it was odd that my stock injectors completely maxed out at almost exactly 120% and all the injector calculators i have found said that the red tops should have more then supported my mods
Old May 17, 2012 | 10:50 AM
dr_whigham's Avatar
The Scammer Hammer
Wish I could find some EV1 42lbs at a good price....
Green Giants are EXPENSIVE!!
Old May 17, 2012 | 11:00 AM
thunderstruck507's Avatar
Have you looked into the GM white bosch injectors from supercharged 3800 engines?
That's what I'm running, got them on ebay for $60 shipped. I think the price was a mistake though, but still you might be able to find them for around $100.
You can also have stock injectors resized.
https://ls1tech.com/forums/fueling-i...injectors.html
Old May 17, 2012 | 11:41 AM
groundczero's Avatar
+1 I had fuelinjectorconnection resize my stock 28's into 42's and they have performed very well.
Old May 17, 2012 | 11:44 AM
dr_whigham's Avatar
The Scammer Hammer
I've actually got my eye on two sets of the white injectors.
Part # 0 280 155 881 ?? From a 2003 Pontiac Grand Prix Supercharged
Old May 17, 2012 | 11:48 AM
dr_whigham's Avatar
The Scammer Hammer
Nevermind. I just bought a set of the ones you mentioned, Thunder.
146 shipped, all new o-rings and filtrer baskets, and flowmatched to within 2%.
Thoughts?
Old May 17, 2012 | 03:20 PM
dr_whigham's Avatar
The Scammer Hammer
Title change with a new part #
Apparently the are Bosh design 3's. I take it that's good?
Old May 18, 2012 | 07:20 AM
dr_whigham's Avatar
The Scammer Hammer
Pics added
