Custom MAF?
After doing a lot of reading about the 100mm MAF's having issues even after running a screen (not all, just some) I had an idea. It's my understanding the issues stem from a lack of velocity over the new card style MAF.
So, here's my thought- Utilizing the material below, I would make my own 3.5" diameter (85mm ID) MAF, vice the 4" MAF (LPE / TSP 100mm) in hopes of not only gaining better unrestricted airflow, but also trying to help velocity for better readings.
I thought about the GM 85mm MAF, but there's still a lot of "stuff" on the inside creating turbulence. Well, that, and it's something I can make and call my own. I will also be adding a SAXON PC MAF Screen to straighten airflow.
I'm thinking it should be easier to tune, and give a better benefit to having a true 85mm MAF.
What do you guys think?
I have known others to make their own MAFs it can work well if you put the time in to get it retuned. Believe one tuner made an oval one to match the LT1 TB. If someone can do that your project should be easier especially the tweaking the tuning part.
Geoff will be tuning the car though, so hopefully I'm covered.
I figured somewhere out there someone had done this, just never ran across a thread. Figured I'd thow it up here for others that might have had the same idea.
I'm ordering this stuff and am going to be the guinea pig. Maybe it will work great we have a new alternative to the 100.
This counts as a "poor man's patent" right?
I'm guessing I need a pigtail now....
Guys, would you suggest using the IAT built into the card LS3/7 MAF, or continue to use my regualar IAT sensor?
Parts are all ordered.... should have it together late this week.
It's the "black magic" GM discovered I'm trying to figure out. The Cobalt has been using these MAF's since 2005, and the new Camaro's & vettes have followed suit. They get good readings somehow, and I'm thinking an 85mm tube, or an 82mm ID should help tremendously with air velocity and accurate readings.
I still plan to screen it though with an 85mm version from Saxon.
Initial measurements look promising though. Seems the actual portion of the card that reads the airflow will be perfectly centered. May alleviate the issue of "clocking" the MAF that you have to do with the other 100mm units, since they are off a bit to one side.
Pics to come shortly today.
I'll be sure to post pics when I get in (this week) and let you guys know.
