Idle problem on my cammed ls1
Vrx5 cam 243 ported an milled heads fast 90 intake nick Williams 92mm tb 3400 stall converter. Have an idle issue runs fine no CEL but when I put it in gear it idles high an pulls car but b4 the mods u would have to rev it up to move cause stall an now it's pulling an jerking by its self
Have you checked to make sure the throttle blade isnt adjusted too far open. You might check that first and do a TPS reset and adjust the blade if needed. I recommend resetting the TPS after any ajustments are made.
