Sold 03 cobra buying a 98 firebird Formula, few q's..
Well guys picked up a 00 T/A with the following:
Miles: 94000
Transmission: Automatic
Raptor hood: not painted
Kooks 1 7/8 heads
Fast 90/90 Intake
Comp cam. don't know the specs
AFR 205 cylinder heads.
Bigger Injectors
80 mm maf
410 rear gears
Magnaflow exhaust
Precision Industries 3800 stall converter
LS6 short block/has been in car for 4 years and has about 15000 miles on it
Dobble roller Timing chain
ARP rod bolts
Reinforced frame
Transmission rebuilt 2 years ago with GM Performance parts
Brand new Alpine single CD Satellite radio head unit
MTX sub woofer, MTX sub amp
A/C Cold
Paint in good condition with some chips
17" black ZR1 replica wheels/275 40 17 Continental Extreme Contact DW tuned tires in excellent condition.
The guy said the car was dyno'd 5 years ago
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
"Transmission rebuilt 2 years ago with GM Performance parts"
That sounds weird.
Before you do anything do a compression check and make sure the motor is okay before changing anything. You don't know what kind of use the car and motor has been through. Please weld your axle tubes and add a girdle to the ten bolt as well if its not already on there. Thats a lot of power even for an auto in a heavy car for the ten bolt to deal with.
That sounds weird.
^^^ I agree the rear end is goin to need to be addressed at some point because once u hit the 400 mark, even though an auto isn't as rough on the rear end as an m6, a few hard launches on a high mileage rear end and something is bound to give !
#33
Update: Took her to the dyno to ck up on things, the hp was low but ok but the tq was too low for the mods imo, 400/347tq, wondering if the converter was/is unlocked, is there a way to find out? that's the only thing I could think why the tq was so low..anyone?
