What do you guys think
-Kooks 1 7/8-2" 3.5" no EGR jet hot coated (purchased)
-3" True duals no cats (purchased)
-LS6 intake
-SLP lid, smooth bellow
-P&P stock TB
-Delete AIR and EGR
The plan is to eventually do heads and cam so tuning for just bolt on's is not particularly preferred, unless it's necessary. Heads and cam would come a year later most likely.
Seeing as this set up will run rich initially, my question is, would ported MAF ends even out the A/F ratio? Or should I still get a tune either way?
That's my $.02 on it.
You are not going to damage anything driving without a tune, just wont be maximizing the cars horsepower potential.
And where can you get a "good" tune for $2-300 dollars? Full dyno tunes usually range from $400 on up.
Like I said, a year after these bolt-ons are done, the plan is heads and cam. If this set up does not harm the engine then I'll just run it untuned until the following year. I do not NEED to be maximizing the performance of these mods (unless if I for some reason decide against heads and cam).
I bought them used. The headers alone are $1k. Plus the cost for the jet hot coating. I picked them up locally for $725. I don't think they make the stepped headers with a 3" collector anyway.
