Finally fabbed\installed custom 3" duals
Old Jun 6, 2012 | 07:43 AM
mikh338's Avatar
Default Finally fabbed\installed custom 3" duals
so like the title says i finally got around to doing it. i am running a sphon tunnel mount torque arm so running these pipes thru there with an x pipe was not easy or fun but i got it done. i used a ebay universal x pipe, 2 dynomax 12" long bullet mufflers, and 3" aluminzed piping from summit. bought a couple 90 bends and straight pipe. also cut up my old pacesetter y pipe to use for the pipes coming from the collectors. also needed 3" slip fit connectors and u bolt clamps. here the pics!!
driver side pipe
passenger side pipe
bullet mufflers welded together
shot of the x pipe, mufflers and turndowns welded up
and an idle clip
http://s45.photobucket.com/albums/f7...t=IMG_0367.mp4
Old Jun 6, 2012 | 07:45 AM
mikh338's Avatar
no rasp whatsoever and WOT sounds rediculous!! love how deep the tone is but is still very loud. 50-120 yesterday i almost creamed my pants lol
Old Jun 6, 2012 | 08:02 AM
simplysix's Avatar
Looks really good. Idle sounds great. How "loud" is it inside the car while cruising?
I've been considering doing this instead of buying a off the shelf true dual
Old Jun 6, 2012 | 08:07 AM
mikh338's Avatar
thanks alot. its not crazy loud in the car because i actually adjusted my turndowns from the above pic. they are pointed almost all the way to the side of the car to reduce drone and also for ground clearence since im lowered 1.5". it doesnt seem any louder in the car then my pacesetter y pipe and corsa catback was, but sounds so much better and much deeper and it was so wierd driving around in town and not hearing rasp lol
Old Jun 7, 2012 | 01:39 AM
Jdsls1's Avatar
Any pics of it installed?
Old Jun 7, 2012 | 01:47 AM
Blk98Vert's Avatar
Nice job, further proving that duals with a tunnel mount is easily doable
Old Jun 7, 2012 | 02:07 AM
bww3588's Avatar
I want son pics installed. I have the tsp true duals, but I have always wanted duals down one side like you have done.
Old Jun 7, 2012 | 02:09 AM
Blk98Vert's Avatar
Its very easily done in case you are wondering
Old Jun 7, 2012 | 02:12 AM
bww3588's Avatar
I have seen them this way, I Just never got around to doing it since the tsp duals do the job. I Just ran into problems getting the mufflers to fit on each side of the pig when in installed the 9 inch.
Right now, I have a pair of 2 chamber flows so I'm not sure if both will fit down one side.
Old Jun 7, 2012 | 04:58 AM
poloaa009's Avatar
Nice job, further proving that duals with a tunnel mount is easily doable.
Old Jun 7, 2012 | 06:33 AM
TheSilverOne's Avatar
I like!
Old Jun 7, 2012 | 09:01 AM
dabest09's Avatar
Let's see a pic from under the car.
Old Jun 7, 2012 | 10:06 AM
scarybowtie's Avatar
Looks good man. Im a fan of diy projects
Old Jun 7, 2012 | 02:21 PM
Jdsls1's Avatar
Pics of the system installed under the car please. Great set up, I will be doing this. Hate the rasp from my tsp y and don't want to pay the cost of their duals. This set up looks like the perfect option
Old Jun 7, 2012 | 02:26 PM
andy-lswon's Avatar
That actually looks pretty good. I went with the tsp true duals but ures looks better than theirs lol
Old Jun 7, 2012 | 02:32 PM
BAMALS1's Avatar
Looks nice, would it clear a driveshaft loop?
Old Jun 7, 2012 | 02:37 PM
mikh338's Avatar
hey everyone i would not say it was easy in any way. it wasnt the hardest thing but getting the x pipe and both 3" pipes thru my spohn tunnel brace with DSL was not easy by any means. gettting everything to fit and line up without touching or vibrating off anything was not easy either. i will have to get some pics of under the car soon i totally forgot to take pics of that as well as the custom hangers i made, i was just so happy to finally be done i just put the lift down and started it lol.
Old Jun 7, 2012 | 02:38 PM
mikh338's Avatar
yes it cleared my spohn tunnel brace with built in DSL
mikh338's Avatar
and thanks everyone for the compliments
Old Jun 7, 2012 | 02:40 PM
mikh338's Avatar
my old setup with pacesetter y and corsa catback with lt;s and cam was really loud, but i think this may be a tad louder, its hard to tell. well either way its loud lol. but its very very deep which i looovvveee and no rasp is just amazing lol. wot f'n screams as well!! crusing it doesnt really seem like it drones that much since i have the turndowns i made pointed almost completely sideways(due to ground clearence and for the drone aspect)
