will this complete my header install list ? and such
2 Bosch 13111 oxy sensors
tr55 plugs
msd wires
12 stock gm manifold bolts
2 gm metal gaskets
anti seize
zipties
EGR block off plate
which band clamps do i need for my tsp ory ? i heard accuseal is good then i see the stainless steel ones on both the ws6store and texas speed store, ws6 store sells them a couple bucks cheaper, do i need 2.5" or 3" or larger ?
Also have a question about poly motor mounts, what will be involved for removing the stock motormounts and installing the poly's ? any cutting of the clamshell ? I'm having the guy doing the hp tuner install all of this and i dont want to hopfully (manifold bolts snaping off etc) tie him up for too long.
Sorry, can't help with the header stuff.
It took me 2 whole days to do my headers and poly mounts, but I was also alone and had to stop working at times to take care of the business I'm running.
Do it.
Took me about 2 days to do my headers, but I went slow, was by myself and it was like 95 degrees out. I used pb blaster on the bolts the night before and took my time cracking each bolt and spraying some pb in, make a turn and spray some more in. Luckily none of mine broke, the y pipe where it goes into the stock catback didn't fit good on mine but you have a magnaflow right?
