Return of the FAST 92mm intake!
Once people wake up, it will be a bigger hit.
They usually cut the back of the intake and re-locate the MAP sensor or they mess with the firewall.
For a C6 the 102 is an easier bolt-on, for the C5 and f-body the 92 is an easier bolt-on.
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Ask Tony Mamo/Peak/Veneg etc which intake is better on a 346 ported or not. Tony's answer might suprise you and he has a lot of experience with them all.
I'll stick to a LS6 intake unless I had a 408ci or bigger LSx motor. Then a 102mm would go on for the same price as a 92mm.....
Also with a 102mm on a F-body I came to find out that your throttle cable will be a lil short if you run a 102mm TB also. The cam gear is bigger and you will need to adjust the cable and in my case lost CC due to this adjustment. And REALLY did not like the fitment in a F-body, so against a 102mm in a f-body.
