Return of the FAST 92mm intake!
Old Jul 1, 2012 | 07:41 PM
  #101
Blk98Vert's Avatar
Originally Posted by Firebirdmuscle
I would hope he would gain more than 15 hp just in h/c much less just the intake on top of that
As stated I was talking about another 15 over the LS6 on top of a H/C motor. 15 is the lowest ive seen, with 40ish being the highest ive seen
Old Jul 13, 2012 | 04:12 PM
  #102
Turbo306Fox's Avatar
Damnit why it gotta be so difficult! Good looking black 92 or a grey 102 or a ported 102 hmmm so many choices just sucks when you have the money but can't make up your mind what route you want to go
Old Jul 13, 2012 | 04:26 PM
  #103
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
What are you working on, what's your current setup?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jul 15, 2012 | 04:56 PM
  #104
Stock bottom end decent size cam ported heads LTs ls6 intake true duals it making around 430 wheel now
Old Jul 19, 2012 | 11:06 AM
  #105
OldCobraGuy's Avatar
Man...I wish they had been more reasonable with their pricing. That is a ton of money. Especially when you can get the Edelbrock for about half that price. Of course, installed prices (extra parts needed) could change that. Well, the more I think about it, I would rather give FAST 5 times that price than give Vic Edelbrock a dime of my hard earned money...
Old Aug 1, 2012 | 06:41 PM
  #106
Drew-Bot's Avatar
Thinking about buying one in september. I have a 383 stroker with the tsunami cam from texas speed and the 5.3 stage 2 heads. Would I still want the 85 or go with a bigger one because of my higher ci?
Old Aug 2, 2012 | 05:16 PM
  #107
badazz81z28's Avatar
The new one still isnt a bad deal considering what people are asking for the used ones. I see used 92s on here $700+ all day long....
Consider the Black 92mm is:
1. Nicer and New
2. Comes with hardware
3. Stainless bolts are holding it together
4. The TB mounts are now threaded inserts.
Old Aug 4, 2012 | 04:53 AM
  #108
85IROCZmaro's Avatar
^also can use stock ls1 fuel rails as well instead of buying ls2 works for me since i have a set of ls1 style fast fuel rails
Old Aug 14, 2012 | 06:38 PM
  #109
a_ahmed's Avatar
For an L33 would the fast 102 or 92 be a good option? Road racing oriented build
Old Aug 14, 2012 | 09:15 PM
  #110
The FAST 102 is an overall better/newer design over the 92mm. If you are not concerned about buying new rails or using LS2/LS3 rails, Go 102.
The only benefit the 92mm has is the utilization of the stock LS1 fuel rails and fitment on corvettes.
Old Aug 15, 2012 | 08:46 AM
  #111
Sail Hatan's Avatar
after my converter, im thinking about picking up a fast 92, with a 92mm throttle body. will I gain enough to justify it over my current ls6 Ported stock tb set up?
Old Aug 15, 2012 | 08:52 AM
  #112
jrob56's Avatar
Ya I would think so, sell that setup together for like 400-450.
Old Aug 15, 2012 | 05:31 PM
  #113
The dollar to Horsepower....No, it really doesnt justify. Money can be spent elsewhere.
If you are trying to squeeze every last poney out of the engine, Yes. AND even than if that is your flavor...I would go FAST 102/92mm TB
