Stall size for Ms3 cam for DD
I was told differently by a prominent tuner here on the board, Phil from Tampa Tuning.
With a proper tune and line pressures, the tqm can be completely removed and the trans can be tuned to run normally under normal driving conditions and can be more aggressive under hard acceleration.
I believe that's what he said, but you can ask him directly.
The A4 transmission has about 20 tables that I address for tuning.
The A6 has about 275. It takes about 45 minutes, but to get my baseline transmission tune in before I customize it for the client since everyone likes their transmission to shift slightly different than the next driver.
With the A6 through the torque adder table, I can make the A6 shift quick and firm in both modes for cruising and "normal" part throttle driving, and then hard, fast and chirp at WOT.
Both modes, D and M I can make a his and hers for the married guys. I really like the A6 when tuned, its just a PITA getting there lol. Some of the A6s seem to have a mind of their own, and you can’t just cut and paste them to work.
The A4 doesn’t have the same adder platform, but does have some flexibility, but not like the A6. A4 does have Normal and performance tables, but the performance tables are mostly max'd out already for pressure and Shift MPH. I can soften up shifts in one mode by making them come one earlier and the performance tables make it shift later to carry inertia and make it harder shift.
Not to confuse the torque management with traction control. I don’t like removing traction control parameters because you can turn that on and off as needed.
That's different that TqMgt where GM schedules how much power it wants your vehicle to have at certain power levels. Tuners don’t like that. We want you to have all your power whenever you want all your power. Traction control I look at as a safety issue that the driver should control.
I can use the TqMgt to assist very high horsepower vehicle with traction out of the hole, then remove it once moving down the track.
Stalls, great for digging out of the hole, if to large, not as fun cruising because they are stalling your RPMs, slipping around if you will. sometimes you just have to pick your evils lol
that's Phil's little 2 cents.
You will be pleased with your converter. I had a 3800 for years and wanted more-now I do
Get a pan from a truck for your trans as well.
Just wanted to put it out there, it really probably depends on how you're driving the car and lots of other variables.
