car wont crank need help asap plz, need car moved asap
Old 07-13-2012 | 08:56 PM
devic's Avatar
alright so now i can turn the key and its running for bout 2-4 sec, well trying to run with out holding the key
so basically i turn the key till it bust over then let off and its trying to run on its own power for bout 2-4 seconds then dies
Old 07-13-2012 | 09:35 PM
USMC35thSS's Avatar
It's good to see that something is happening. We know that a couple of your coil packs aren't firing. Try checking each coil pack for power and a ground. I am pretty sure the wires are labled A, B, C, D. "A" being the ground and "D" being the power. With the ign on check for power. The power wires are spliced together for all coils on each bank.
Old 07-13-2012 | 10:00 PM
devic's Avatar
coil 4,5,7,8 are firing. 1,2,3,6 are not firing any ideas ?
Old 07-13-2012 | 10:07 PM
sepsis's Avatar
Could it be a bad crank sensor or ring?
When you switch the coils around, do they work and vice versa?
Old 07-13-2012 | 10:13 PM
devic's Avatar
when i switch the coils around from the left bank to right bank the same cylinders fire as before
Old 07-13-2012 | 10:14 PM
devic's Avatar
if the crank sensor was bad wouldn't it not get any spark ?
Old 07-13-2012 | 10:16 PM
devic's Avatar
any 1 have a diagram of the ground points, also now that im thinking bout it idk if i hooked up the VSS idk if that would matter beside when i slow down ?
Old 07-13-2012 | 10:21 PM
sepsis's Avatar
I'm just throwin some ideas around. Are all the teeth on the reluctor ring?
I haven't come across this problem and it seems like you've already been through a lot of troubleshooting.
Old 07-13-2012 | 10:23 PM
USMC35thSS's Avatar
I would think that if the crank sensor was going bad then it wouldn't always be the same coils. I'm starting to think it's the PCM. Not sure though
Old 07-13-2012 | 10:46 PM
sepsis's Avatar
I hope you get it figured out man. I'm no LS genius, just tryin to help.
Old 07-13-2012 | 11:33 PM
devic's Avatar
i really appreciate the help and all ideas are better than none, my brother is thinking maybe a ground wire some where ? could a ground not being hooked up on the harness cause the coil to not fire ?
and idk what would cause the reluctor wheel to go bad, but maybe the crank senor could be going out but like USMC35 said i think t would have more variable in the problem.
im thinking possible :
bad ground / bad wiring / bad pcm, atleast 1 of these idk tho
Old 07-14-2012 | 01:47 PM
  #32
devic's Avatar
still having this issue
Old 07-14-2012 | 02:50 PM
  #33
USMC35thSS's Avatar
The grounds to the coil are all spliced together. So if there is an issue with the ground it's gonna be on the wiring harness attached to the coils. I'm not an expert at this but there has to be a way to test the signal that gets sent from the PCM to the coil pack itself. It seems like that is where the issue is.
Old 07-14-2012 | 03:16 PM
  #34
USMC35thSS's Avatar
Have you actually tested each coil for power?
Old 07-14-2012 | 04:31 PM
  #35
devic's Avatar
any 1 know what pin # are the coil packs from the computer side ?
Old 07-14-2012 | 04:32 PM
  #36
devic's Avatar
i dont have a ohm meter at the moment so i gotta get that be i can continue testing i guess
Old 07-14-2012 | 04:39 PM
  #37
USMC35thSS's Avatar
1- 26, 2- 67, 3- 69, 4- 29, 5- 68, 6-28, 7- 27, 8- 66
Old 07-14-2012 | 04:43 PM
  #38
USMC35thSS's Avatar
Thats the red connector
Old 07-14-2012 | 05:35 PM
  #39
devic's Avatar
ok thank you, so how should i got bout testing so see if powers going threw it ? hook 12 volt to 1 side then ohm meter on the other side ? with the ground going to the body ?
Old 07-14-2012 | 06:09 PM
  #40
USMC35thSS's Avatar
Unhook the connector going to the coil and then turn on your multimeter to VDC. Put the red lead on the pink wire of the plug and the black lead can be grounded to the vehicle.
Quick Reply: car wont crank need help asap plz, need car moved asap
