Does anyone with WS6 use the BG Ram Air setup?
Old Apr 4, 2004 | 12:09 PM
My90Iroc's Avatar
Default Does anyone with WS6 use the BG Ram Air setup?
I was looking at the BG Ram Air kit for WS6 hoods and wondering if anyone has used it? Are you happy with it, happy with the results? Thanks.
BTW: I asking in reference to a 2000 WS6.
Old Apr 4, 2004 | 11:18 PM
99MONGOOSE's Avatar
I plan to get it for my WS6 because I have heard nothing but good things about it!
Old Apr 5, 2004 | 12:05 AM
Racehead's Avatar
I couldn't be happier with mine. I'd buy it again if I had to
Old Apr 5, 2004 | 12:35 AM
2001 White Ws6's Avatar
I've had mine for almost a year now. It's a bitch to install but it's a great design and works well. If you drive a ws6 then you better get the BG Ram Air.
Old Apr 5, 2004 | 01:52 AM
SLP LS1's Avatar
Like they said works well, just a big pain in the *** to install! I had to do a few adjustments to mine. Other than that get it!
Old Apr 5, 2004 | 03:38 PM
mike c.'s Avatar
i just installed mine last night. kind of a pain to do,but why have a ramair that dont work.
Old Apr 5, 2004 | 05:02 PM
TaTommyWS6's Avatar
Installed mine a few weeks ago. Seems to work fine. The fit is great (annoying to install...)
Tommy
PS I can suck up small animals now!
Old Apr 5, 2004 | 05:07 PM
My90Iroc's Avatar
Thanks for all the responses. You guys say it's annoying to install, what's the problem(s)?
Old Apr 5, 2004 | 08:11 PM
Nick D's Avatar
I ordered mine last week and it still hasn't arrived. I CAN'T WAIT. I think the annoyinh part of the install is drilling out the baffles because from what I've heard it's pretty straight forward. Good luck and let me know how it goes because I will installing mine the day it gets here.
Old Apr 5, 2004 | 08:50 PM
Mike98WS6's Avatar
I installed my BGRA last November. It took me an hour to install. It makes a big difference once the car goes faster.
Old Apr 5, 2004 | 10:51 PM
Well to make it very easy to install the BGRA you can remove your entire hood and it'll be a cakewalk. That's too much to do so no one would do it that way.
The reason why it's a PIA to install is the awkward position you have to be in to install it entire time. If you are a small guy then it shouldn't be too much trouble. Other then that it's pretty straight forward.
Old Apr 5, 2004 | 10:59 PM
qane's Avatar
I've considered this kit as well but I'm curious what gain the entire kit has over just having removed the baffles myself. I realize the air still isn't being strictly directed into the intake.
Does the inch gap being sealed make that much of a difference? Enough to warrent a $200+ pricetag?
Old Apr 6, 2004 | 01:42 AM
SLP LS1's Avatar
Old Apr 6, 2004 | 11:29 AM
If you don't have the hood sealed to the airbox then you'll have a shitload of turbulence and wasted air exiting around the airbox.
With the airbox being sealed to the hood you have a straight shot of air right into the airbox. Much more efficient.
Old Apr 6, 2004 | 11:47 AM
Ohio Bird of Prey's Avatar
Default BG ram Air? $200?
Anyone with a link to this product.
I've removed 1 baffle so far and I was
getting ready to seal the front of the box.
Would like to know what you guys are talkin
about.
Old Apr 6, 2004 | 01:00 PM
Nick D's Avatar
just go to yahoo! and run a search for "brian green ram air" it'll be the first link, don't try "BGRA" you'll get some other baseball links. thats how i found it and ordered it.
Old Apr 6, 2004 | 02:53 PM
SLP LS1's Avatar
www.ls1speed.com -under intake
Old Apr 6, 2004 | 03:00 PM
Jay02LS1ws6's Avatar
This is the first I have heard about this kit. So it involves removing the baffles in the hood? Wouldn't this be risky driving in the rain? Sealing the box to the hood sounds liek a great idea, but can someone clarify about the baffles?
Old Apr 6, 2004 | 05:26 PM
I've driven in downpours without the rain deflector plate in. Hell i haven't even used the rain plate since i've had it. I wash the car with it out and still no problems. You won't encounter a problem unless you are driving through a solid wall of water or a very big puddle and washes on in the hood.
There are the front and back baffles on each nostril opening. Take them both out.
BG Ram Air System site
This link has all the instructions you will need to install it.
Old Apr 14, 2004 | 01:03 AM
Razor's Avatar
Does anyone know if this kit will work on an aftermarket WS6 hood?
If so, I am sold.
Regards, Ray
