Alternator, battery replaced, no charging. 1 loose red wire?
I just replaced both the battery and the alternator in my wife`s `98 Trans Am and it still is not charging. I noticed though that when I installed the new alternator, I only had the main positive wire that I had to disconnect. I noticed a red wire hanging loose above the alternator, but am not sure if this is supposed to connect to the alternator?? If so, would that keep it from charging?
On another note, this was a difficult install for just an alternator. I wish they mounted these on the top of the engine like the LT1.
Thanks.
Thanks.
^^yep, I'd try to locate another plug, whether new or used. Though, the plugs in a harness aren't hard to fix. They usually require a set of dental picks or a paperclip. You basically remove the weatherpak section (inserted rubber grommet) then from the other side insert a straight pick to release the square connector section, it will pull out of the backside while you are holding the release clip down. Once removed, you can attach any wire you like to it, then simply re-insert it back the way it came out and re-install the grommet and its as good as new.
