6" velocity stack intake
Old Aug 13, 2012 | 09:50 PM
BennyB's Avatar
Default 6" velocity stack intake
I've been contemplating building a velocity stack intake. I'm thinking of going to a 92/ 92 or 102/ 102 fast and want to build an intake rather than buy a bigger lid, maf, tubing, etc. ( I do plan on going SD). I just wanted to know if anybody has experience with this, pictures and where to buy from. Any help or suggestions is much appreciated.
Old Aug 13, 2012 | 10:18 PM
jlcustomz's Avatar
http://www.alsblowers.com/streetinduction.html
Something like this??
Old Aug 13, 2012 | 10:27 PM
BennyB's Avatar
Originally Posted by jlcustomz
No it's a single stack that you can run to an opening in the front bumper
Old Aug 13, 2012 | 10:38 PM
1989GTA's Avatar
Try www.velocity-of-sound.com I bought their 6" x 4" velocity stack and it was a real nice piece. Look under turbo bellmouths for the size you want. Click on the picture.
Old Aug 14, 2012 | 11:20 AM
BennyB's Avatar
I wonder how they compare to vibrants velocity stacks I noticed theirs are a little cheaper
Old Aug 14, 2012 | 03:38 PM
NC98Z's Avatar
I don't think theres enough room to squeeze all that under there!
Old Aug 15, 2012 | 04:17 PM
imma_stocker's Avatar
Where exactly are you planning to run the velocity stack? Do you want to integrate an air filter or are you completely ditching the filter?
Old Aug 15, 2012 | 05:32 PM
BennyB's Avatar
I'd like to be able to run a filter for when I cruise or street drive the car. It's a trans am so I was thinking of using the lic plate cutout or trying something with the fog light openings
 Michael S. Palmer
Old Aug 16, 2012 | 12:53 PM
That's gonna be tricky then. You have two options to run a filter too.
1. Run a bellmouth velocity stack up front then piping to a sealed charge box with a filter, then from there to your throttle body.
I think a Mugen type filter setup is what you'll need to keep the velocity stack working. But idk if it'll still work like that. If it's going to work the entire system has to be sealed and you can't let water get sucked in there. Pretty sure quality cone air filters are designed to work like a velocity stack though.
2. Put a velocity stack air filter on the bellmouth so air is filtered up front.
Google velocity stack filter and you'll see what you gotta do.
Old Aug 16, 2012 | 01:14 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
would it defeat the purpose of the velocity stack if you run a filter?
Old Aug 16, 2012 | 05:34 PM
jlcustomz's Avatar
Spectre makes a plastic chrome bellmouth. They also have inline filters.
Ryne ,the function of a velocity stack is to cram more air into the smaller sized opening, The given filter won't affect it anymore than a non velocity stack opening.
Old Aug 17, 2012 | 12:28 AM
DopeFedZ's Avatar
More pics in here
https://ls1tech.com/forums/generatio...cment-cai.html
Old Aug 17, 2012 | 05:19 AM
BennyB's Avatar
Originally Posted by DopeFedZ
Wow, very nice looking setup. If I do end up running a filter I would probably just want to be able to slip something over the bellmouth. Remember this is just for when I drive the car on the street and I never drive in rain.
Old Aug 17, 2012 | 05:32 AM
roninsonic's Avatar
they make large diameter cone filters that will fit over a nice velocity stack. That would be your best bet for street use... And yes, running a stack and then a filter is pointless.
Old Aug 17, 2012 | 04:01 PM
You CAN use an inline filter but you'll need trial and error testing or a fluid dynamic simulater to maintain laminar flow through the intake stream.
There are 3 filter types to run with a stack. The mushroom looking cap that goes on top, a true velocity stack filter (cone filter on top of a velocity stack), and the plug type that goes into the stack. The true velocity stack filter is the best IMO because the cone flows and filters the best.
Up to you what kind of filter to run but first you might want to skim this.
I might end up making something like this for 4" piping. 7" filter base funnel down to 4" piping ought to breathe pretty good
These guys sell what you need. http://vibrantperformance.com/catalo...Path=1022_1220
Old Aug 18, 2012 | 12:47 AM
DopeFedZ's Avatar
If you need a filter vibrant sells one that fits their stack
