3" exhaust with UMI short TA, Who has pic of theirs?
Good to know, i may space the cross member down 1/2" to get nessacary clearance. I just finished up hacking up my TSP Y and used some old mandrel bends to get two 3" pieces over the tunnel mount. Pretty sure i wont be able to run a DS loop but i do believe i will order some NEW mandrel bends from a sponson so i can redo it this winter casue it is kindo of a hack job pic later tonight or tomorrow.
Is it going to make a differance if i put the spiral flows on before the X pipe? Like upstream from the X?
Here is the first exhaust I did, Cleared everthing when i originaly did it till I purchased a Tunnel mount TA.
![](http://i760.photobucket.com/albums/xx242/k_cash1432/photobucket-893-1346745537192.jpg)
And here is the pic of the finished piece. Hangers are bolted to the underside at the tips of the bullets and i will put one in the middle some where.
![](http://i760.photobucket.com/albums/xx242/k_cash1432/photobucket-33235-1350105427793.jpg)
I will redo it this winter with an true X pipe and alumized exhaust this winter when I get my lift put up in my gurage. I know its not the prettiest but It doesnt hang much lower than the K or trans mounts so their is still allot of ground clearance.
