Fast 102 owners
FYI you can get used GM 90mm MAF's on ebay all day for $40-$50. Then you'll need the wiring harness....think that was like $20. I don't know what I gained from it as I did from lid to FAST intake at the same time. I got one because I didn't want an SD tune for several reasons, one being they are more money.
I don't know what the difference would be between a 100mm and 90mm MAF on a 102 setup. I can't imagine it would be that much especially on just a H/C car.
On a stock cube head and cam motor, not so much. It isn't so much the inlet size opening that factors into how much power you make. It's the superior runner design of the FAST intake that makes the increased power.
If you watch the dyno section here you will likely find it takes a stout heads/cam combo creeping over the 480rwhp range to benefit from the larger MAF than the 85mm.
The easy way is to just log for vacuum at WOT. It will tell you if you're choking it or not.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
