fast 102 and fast rails. issues?
Old Oct 27, 2012 | 06:03 PM
sdimex's Avatar
Default fast 102 and fast rails. issues?
so i bought a fast 102 intake n tb . i was told that the fast rails lift up and have issues .
has any one here had any issues with fast fuel rails?
if your using a fast 102 what rails are you using?
Old Oct 27, 2012 | 09:31 PM
1slowbusa's Avatar
I have the fast 102 with the fast fuel rails and have no issues.
Old Oct 28, 2012 | 04:00 AM
Undertow74's Avatar
i had issues with my drivers side Rail. The shitty little metal stanchions that they come with are not worth a damn. my front 2 injectors were leaking from under the rail. I had to use a couple small washers under the rear rail mount to shim it up to let the front go down more so the injectors would seat properly.
Old Oct 28, 2012 | 08:50 AM
Sales1@Texas-speed's Avatar
I've have yet to run into this issue yet when installing the Fast 102 intakes and fast rails.
Old Oct 28, 2012 | 11:17 AM
Undertow74's Avatar
@ Aaron--
Well must have been just my luck. This is the same Fast 102 that got a magical crack in the back passenger side by one of the injectors and i had a bad vacuum Leak. I sent pictures to Comp Cams and they couldn't explain it, so i shipped the intake to them and they sent me back a brand new one free of charge....
Old Oct 28, 2012 | 12:06 PM
That is odd, glad Comp got you fixed back up!
Old Nov 13, 2012 | 01:50 AM
sdimex's Avatar
2 cars by me went up in flames when the rails lifted
Old Nov 13, 2012 | 02:23 AM
JakeFusion's Avatar
Super Hulk Smash
What rails? The billet rails or the LS2 OEM rails?
Old Nov 13, 2012 | 02:24 AM
sdimex's Avatar
fast billet for ls1
Old Nov 13, 2012 | 08:32 PM
Pharcyde50's Avatar
Fast billet here with a 102 and no issues here. Everything bolted up good and solid.
Old Nov 13, 2012 | 11:14 PM
backdraft408's Avatar
im using stock ls2 fuel rails and im having no problems and no leaks.
Old Nov 14, 2012 | 06:04 AM
therabidweasel's Avatar
Ls2 style fast rails and no issues.
Old Nov 14, 2012 | 09:02 AM
ngeno626's Avatar
i used edlebrock and no issue
Old Nov 14, 2012 | 12:38 PM
Nasty N8's Avatar
You need a set of full billet Nasty Performance rails.
Short inj
http://www.nastyperformance.com/shop...ck-fuel-rails/
Tall inj
Old Nov 18, 2012 | 08:46 PM
marc.madmax's Avatar
I had similar prob with NXL nitrous unit. mounts would loosen up and blow out injector o rings. red locktite is great on those mount bolts. haven't moved til I went and rebuilt motor.
Old Nov 18, 2012 | 10:18 PM
JakeFusion's Avatar
Super Hulk Smash
Those Nasty rails are works of art.
Old Nov 19, 2012 | 04:19 AM
themealonwheels's Avatar
I would have lost my engine if I hadn't had a stand-by when I tried to fire my stroker with the billet rails the first time. It was like a sprinkler system with the fuel spraying from nearly half of the injector tops! I switched to LS2 rails and haven't thought about it.... until now that you mention it, lol.
LS2 fuel rails ftw
