Thoughts on my build.
EPS custom grind cam to match heads (was gonna get 236/248)
TFS 220cc heads (worked by brian tooley)
chromeoly push rods 3/8"
C5R timing chain
LS6 p&p oil pump
TSP 1 7/8" headers
TSP rumbler X 3" TD's (with sweet thunders)
SLP lid
SSRA intake
85mm MAF
FAST 92mm TB
FAST 102mm intake
LS2 water pump
FIC 42lb injectors
Racetronix 255 fuel pump
MGW shifter
Monster stage 2 clutch (either 11" or 12")
Lightened flywheel
slave cylinder
Tick speedbleeder
Tick master cylinder
UMI suspension:
- adjustable LCA's
-SFC's
-adjustable Pan hard rod
-Sway bars
-Torque arm
- single adjustable Coil overs (lower about 1.2")
alright thats everything. If i buy everything brand new it totals about 11k. Let me know what you think. Thanks
Talk to Brian Tooley about getting them with turned down LS3 valves (stock Ferrea in TFS heads are 110g... turned down 83g!) and running PM Guides with his Platinum Springs. Total for that is about $1975 and then you can run your stock rockers with a Comp Trunion upgrade. It'll have a more stable valvetrain and make more power. Also, he'll hand finish them for like $300 and it'll make as much if not more power than TFS 215s for less total cost. I'd also run BTR 3/8" pushrods since they are only a little bit more than the 5/16" and fit the TFS heads. More stability = good.
Throw some new lifters/trays in there too especially if you're over 60k miles. And the LS2 timining chain is good - the C5R chain is another $100 but it'll last forever if you want to go that route.
Also, I think you can just run the SLP lid and the stock MAF and make the power you want and save some cash there. I've talked to more than one vendor who says this is the optimum setup unless you are at like 600rwhp with a 454 or something.
Everything else looks fine but I'd do springs/shocks before any of the other suspension stuff. Talk to Strano - the biggest problem with the car is the stock DeCarbons are total crap. The stock springs are actually okay and launch pretty good. Just needs better shocks.
http://www.texas-speed.com/p-3937-cl...-bolt-cam.aspx
is this the chain youre referring to?
Also $500 for a UD pulley for 5hp isnt really worth it.
And this is the chain (though it's cheaper through Katech and every other vendor at 149.99):
http://www.texas-speed.com/p-2281-iw...ing-chain.aspx
