Best way to connect magnaflow y pipe to flowmaster series 10 single chamber muffler??
Is welding the two pipes together the only option? Is there other options besides welding?
Thanks
Thanks
If you don't want to weld it you can band clamp it or have an exhaust shop swell the pipe and slide one inside the other and then and clamp or use a regular muffler clamp. Just make sure you've got a hanger before and after the connection or you may lose your 10 series.
