TSP True Duals install with BBK Headers + Pics
Well, the first problem I encountered was that basically, the setup was too narrow, well for me atleast, because I understand they are made to work with their own headers etc. So I had to go to a local exhaust shop to have them make an extension to reach the rest of the pipes going into the x pipe. You can kinda see that in the second pic.
Then there was the obvious problem of the flanges, my first idea was to maybe cut the flanges off the y pipe and clamp or weld them onto the true duals but the y pipe was simply too small. So the only other thing to do was to take the headers off and grind the flanges off so that the pipes would slide over the headers and I could clamp them using the supplied clamps. (Note I had to grind the clamps to fit around the o2s for it to fit all the way on the collector.
And once we got everything hung up there and bolted down it was cake
(oh and btw relocate the fuel lines before hanging the exhaust lol) And another thing; I didn't like the way the car looked without exhaust tips so if anyone needs some advice about it, a good way is if you make some brackets as shown and mount them up to the back bolting into the bumper bolts it works great to fill those gigantic holes in the bumper.
Hope this helps anyone with the BBK headers that wanna run the TSP dual setup
http://s1302.beta.photobucket.com/us...tml?sort=3&o=0 Last edited by av8er1555; Dec 28, 2012 at 11:24 PM.
