Suggestions for Exhaust Clamps
Old Apr 16, 2004 | 03:41 AM
onyxxtreme's Avatar
Default Suggestions for Exhaust Clamps
Hey people, Im just wondering what all clamps do you guys prefer for the header to Ypipe connection.
I got Pacesetters, and my Ypipe will be custom built, so I need to gather all the nicknack parts 1st. I'll need one for the Ypipe to the Ipipe, but I might just use 3bolt flange's if there's enough room under there.
Heres a few things Ive seen on Ebay, or on here:
"Typical" Band Clamps:
"Flat" Band Clamps:
V-clamps:
I wouldnt mind having the following "Exhaust Locks", but they are far too expensive for my budget.
Now I've read on here, that the V-clamp's are the way to go, but it seems to me that they will hurt clearance almost as bad as the 3bolt flanges. Does that look like it would to you guys too?
ALL opinions are appreciated , thanks guys
Old Apr 16, 2004 | 01:07 PM
Onyx Z's Avatar
I have the wide band clamps on my exhaust. They seal very well and still retain the ground clearance.
Don't use the thin bamd clamps. They came with my y-pipe, but I soon found out they couldn't be tightened down very much before the bolts started to strip, so they wouldn't seal up very well. They wide ones have nice, beefy bolts, so you can crank down on em without worry.
Old Apr 16, 2004 | 02:48 PM
Z28Venom's Avatar
Whatever you do, DON'T USE U-BOLT CLAMPS. I used 2.5" and 3" stainless steel band clamps on my entire exhaust, and they seal like a champ. You won't be disappointed. The average price is $8-10 a piece.
http://groups.msn.com/MikesFirebird/...ndexhaust.msnw
You can see them in some of those pictures.
Good Luck Man!
Old Apr 16, 2004 | 03:42 PM
Tranzor's Avatar
I used the first style of band clamps that you posted... here's some pics of them in use on my Pacesetters:
Old Apr 16, 2004 | 04:21 PM
Turo's Avatar
Originally Posted by Z28Venom
Whatever you do, DON'T USE U-BOLT CLAMPS....
i agree, i learned that the hard way. i had u-bolt clamps and they leaked like crazy
Old Apr 16, 2004 | 08:37 PM
DaddySS's Avatar
I like the walker HD stainless band clamps. The block is threaded so you don't have to worrry about holding the nut, they're really strong, and they come with a dab of sealer at the joint for extra seal insurance.
Old Apr 16, 2004 | 09:16 PM
S2002S's Avatar
The wide band clamps pictured work great, if the joining pipes are straight. If there is a curve near the joint, they are useless. I ended up with the guillotine style on two connections. These worked great and were preferable to a weld job, in my opinion. I did lose a little ground clearance though.
Old Apr 16, 2004 | 10:32 PM
1BADFNZ's Avatar
Where can I get some of these good band clamps???
Old Apr 16, 2004 | 10:35 PM
Dope's Avatar
Yeah, where can you get those top clamps? Those are perfect. They are even slightly different sized at each end to account for slip fit pipe size differences. I bought some clamps but they were completely flat == not such a good seal.
Dope
Old Apr 17, 2004 | 12:00 AM
Tranzor's Avatar
I got the band clamps at the top from Napa... they were $7.99 each for 3" band clamps.
