Help picking cat back/cut out combo for Big Cam
Old Feb 3, 2013 | 02:23 PM
jdhedman's Avatar
Default Help picking cat back/cut out combo for Big Cam
Hello
I am trying to decide what catback cut out combo to go with, I have no problem building a custom system with separate mufflers but I need to get the car quieter than it is now, I would like to have the cutout so I can get loud and rowdy at times and get the flow when needed.
Right now I have a custom Off Road Y pipe (that is rotting and needs to be replaced) Slp LT headers and a Borla Mouth ( SLP Loudmouth with bullet swapped to Borla XR1) It sounds great at idle other than leaks from Y pipe but sounds shitty when full throttle or just cruising, it drones and is too raspy for me.
here is the H/C/I info
- Patriot LS6 Heads 64cc
- Speed Inc Cam 238/244 .605/.612 110 LSA
- LS6 Intake
click link at top or jump to 1m55s
My ultimate goal is to make is sound quiet while having a nice rumble when the cut out/s are/is closed and have the option for that I am going to eat your prius sound when needed with cut outs open
Any advice is appreciated
So what would you recommend?
Thanks
Jeremy
Old Feb 3, 2013 | 04:51 PM
97camaro383's Avatar
My TA has the slp power flo and it tames the sound down alot but still gives it a good sound IMO.
Old Feb 3, 2013 | 04:56 PM
BOBS99SS's Avatar
Captain Double Post
Imo, powerflo is nice but will still be on the loud side,the best option is a magnaflow catback,with a cutout,now with the mods and a ory the magnaflow sounds pretty good,and its the tamest catback there is,unless ya do a true dual with some magna paks over the axle and dual cutouts that is what i would do,magnaflow catback sounds pretty good i like it,just didnt have that sound i love but then again thats why you get a cut out
Old Feb 3, 2013 | 06:17 PM
SWEET98SS's Avatar
I have the mufflex hidden tip with the magnaflow, no drone, quite while cruising but loud when you get on it. I came from flowmaster with a cutout and am still satisfied with the sound.
Old Feb 3, 2013 | 09:42 PM
jdhedman's Avatar
Thanks for the info so far, I have considered the mufflex setup and even a TD setup. I will have to look for some sound clips. I may even just add some mufflers/resonators after the axle and before the tips and keep the catback, Anyone have good or bad experience with cutout brands?
Old Feb 3, 2013 | 10:11 PM
mjs1012's Avatar
Magnaflow catback with any cutout. Quiet when cruising and loud as hell at the flip of the switch.
Old Feb 3, 2013 | 10:41 PM
hodge9386's Avatar
^ thats what i run.
Old Feb 4, 2013 | 12:13 AM
chadroosa's Avatar
i have a ory, dmh cut out, and flowmaster, loud with cut out open, and nice low/ aggressive not with t closed.. no drone in car with cut out closed either.. really quiet actually..btw my cam is pretty close to urs..
Old Feb 4, 2013 | 11:40 AM
jdhedman's Avatar
seems loud in that video, is the cutout open at the end or in the beginning? Sounds mean though
Old Feb 4, 2013 | 12:27 PM
chadroosa's Avatar
video is louder than it really is.. open at the begining and closed at end..
Old Feb 4, 2013 | 12:39 PM
bp m1009's Avatar
MAGNAFLOW best/quietest sounding cat back with LTs. thats what i have with cam LTs ORY and is very mellow at idle no drone when driving and great tone at WOT
Old Feb 5, 2013 | 06:16 AM
omarrakeen's Avatar
Magnaflow, Magnaflow, Magnaflow. i cant believe how quiet it is!! i have LTs ORY and i have tried no mufflers, stock catback, flowtech catback and finally magnaflow catback..this thing is VERY tame! at idle it is absolutley quiet! it get loud above 3k-4k rpm which works out for me. i think with a cam it would rock. keep this updated.
Old Feb 5, 2013 | 10:27 AM
BOBS99SS's Avatar
Captain Double Post
Now i will add when i switched the magnaflow for some duals my big cammed car made way more power and pulled harder threw the hole rpm range,but for street car magnaflow n cutout is the best way to go,and the magnaflow catback looks the best
Old Feb 5, 2013 | 10:31 AM
TXZ28LS1's Avatar
If I were to do a catback, I would opt for borla!
Magnaflow is to quiet. Sounds good though
Old Feb 5, 2013 | 12:17 PM
LopeyZ's Avatar
I would first put some cats on it and then see what you think.
Old Feb 5, 2013 | 12:23 PM
autogeek23's Avatar
(raptr cammed) i run LT's ory and a magnalfow catback. its not too loud or too quiet. but at some drive thrus i have to turn my car off. i want a cutout so it can be real loud when i want
Old Feb 5, 2013 | 07:13 PM
jdhedman's Avatar
Thanks for the input. I am gonna have to look into magnaflow, Should I do the entire catback or just do a muffler and maybe some cats, I want this thing QUIET when the cutouts are closed, But still have a nice mellow rumble to it.
Old Feb 5, 2013 | 08:51 PM
jdhedman's Avatar
Were is the best place to get either a muffler or Catback and cutouts?
Old Feb 5, 2013 | 09:22 PM
z-maro's Avatar
I would also recommend looking at the Hooker Aerochamber, it is known to be on the quite side. I will say though that it gets pretty loud at WOT.
Old Feb 5, 2013 | 09:38 PM
bp m1009's Avatar
get the whole cat back. you can pick em up used here pretty cheap
